Cage questions - JeepForum.com
post #1 of 5 Old 11-26-2012, 11:18 AM Thread Starter
thantos858
1974 CJ5
Cage questions
Working on rebuilding the CJ at the moment and want to tie the cage to the frame. Need the best options for strength fab wont be a problem as the father in-law (professional welder) will be helping me. We don't have a bender or access to one so want to limit the bends needed because of cost.
I also need to extend the cage height. For the height would I be able to just cut it where I want to extend put a insert in it then weld it back?
thantos858 is offline
post #2 of 5 Old 11-26-2012, 04:48 PM
biggoofy
Look for a pre bent cage kit
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #3 of 5 Old 11-29-2012, 02:30 PM
The_Eng
Genrite has a really nice kit that you can purchase with a tie in kit for the frame
http://www.genright.com/ProductInfo....ductid=GRC1001
The_Eng is offline
post #4 of 5 Old 11-30-2012, 04:44 PM
93_bigbadxj
Dom bushings from barnes4x4 on every spot that connects to the cage. A square plate with 3-4 holes thru the floor to sandwich the body between the 2 plates. 2 tabs off the square plate to bolt the Dom bushing to and then tube from that to the frame. Should be able to do it without any bends. If you have sliders that are connected to the frame then just connect the tie ins to that.
93_bigbadxj is offline
post #5 of 5 Old 12-01-2012, 12:58 PM Thread Starter
thantos858
1974 CJ5
Going to put sliders on but don't have any yet. Thanks for the replies and the genright page lots of help on ideas that I can get done. Will have to figure out something for the exhaust that I have.
