Bronco hp44 ? - JeepForum.com
post #1 of 11 Old 10-07-2012, 09:59 PM Thread Starter
dirt5track
Bronco hp44 ?
I can't find the width in the search function. I'm looking for wms to wms width. I'm trying to locate a front axle for my yj that is 66-67 inch wide passenger drop.
Thanks in advance.
dirt5track is offline
post #2 of 11 Old 10-07-2012, 10:36 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Here's some info. Check the links in the thread too.
http://www.jeepforum.com/forum/f310/...my-wj-1307619/
Joe Dillard is offline
post #3 of 11 Old 10-08-2012, 10:25 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Bronco isn't passenger drop.
ratmonkey is offline
post #4 of 11 Old 10-08-2012, 10:35 AM
neagtea
77-79 f-150 rears are are 65" wmsx2. I would say the same for the front.
neagtea is offline
post #5 of 11 Old 10-08-2012, 11:33 AM
jp360cj
1977 CJ7
Are you really looking for a passenger drop or was that a typo? Broncos are drivers drop, but so are factory YJs
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #6 of 11 Old 10-08-2012, 05:51 PM Thread Starter
dirt5track
Typo sorry. I need a drivers drop. Thanks for all the info
post #7 of 11 Old 10-08-2012, 10:25 PM
rchase559
I think my friend's hp44 from a bronco/f150 was 66" wms to wms. Be aware that the 78 and 79 front coil spring housing are just about useless unless you plan on running Ford radius arms.
rchase559 is offline
post #8 of 11 Old 10-12-2012, 09:57 AM
foggybottombob
The 78 and 79 Bronco front axles have a cast iron piece holding the tubes together on each side. So axle tubes are not one piece tubes. The F150 and F100 from 78 and 79 are the same. Finding a pre 78 Bronco axle is rare.
foggybottombob is offline
post #9 of 11 Old 10-12-2012, 08:39 PM
fratis
fratis's Avatar
the fronts are wider. i think the one i have is 67-69" wide...aw crap hold on... its 66.5" wide.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #10 of 11 Old 10-17-2012, 05:32 PM Thread Starter
dirt5track
thanks for all the info, one more question. I have been reading that the f250 axles are slightly wider (due to the 8 lug hubs) than the f150, can I swap the hubs from an f150 axle to get the 5 on 5 1/2 lugs and narow it up by an inch or two?
post #11 of 11 Old 10-17-2012, 08:13 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
not to be too rude, but perhaps you should read a few of the dana 44 bibles out there that cover this stuff in great detail. even going so far as to give you exact part numbers and where they can be found in the salvage yard to get many different width, brake, steering, and lug pattern options on any d44 housing.
start here
http://77cj.littlekeylime.com/web_rs44.html
