Axle Builds and Swaps - JeepForum.com
post #1 of 10 Old 12-15-2011, 11:45 AM Thread Starter
JLC08JK
What was I thinking?
JLC08JK's Avatar
I thought we could use this thread to provide links to custom axle builds and swaps that already exist in other sections of the forum.
Jim's Jeep; JK rear axle build with Super 44s, ARB, and 4.88 gears.
Jim
JLC08JK is offline
post #2 of 10 Old 12-15-2011, 12:58 PM Thread Starter
JLC08JK
JLC08JK's Avatar
I don't think we want to just post up a bunch of random threads, we're not trying to do the job of "Google".
I would have to say that if you built it then please post it
If you learned from it and it's here on J/F then please post it
If you saw it elsewhere and you like it, use that info to build and document it so you can start a thread on J/F and then post it here
How's that for a answer
Jim
JLC08JK is offline
post #3 of 10 Old 12-15-2011, 01:54 PM
Louie4
Here's the ones I posted again. They weren't mine but I posted in the 8.8 build about mine. The others are HPD60's from Joe Dillard and Poke that I followed along with. Of course these are front axles but they typically go well with any jeep.
Joe's HPD60:
http://www.jeepforum.com/forum/f12/h...tions-1216015/
Poke's HPD60:
http://www.jeepforum.com/forum/f12/jeep-envy-1210561/
Sebastian's 8.8 Build/Swap:
http://www.jeepforum.com/forum/f12/f...inally-636291/
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 10 Old 12-15-2011, 08:54 PM
Treton
http://www.jeepforum.com/forum/f8/pr...n-2-a-1279744/
this is the beginning of my build in progress just with a 12bolt to get everything started
Treton is offline
post #5 of 10 Old 12-16-2011, 06:23 AM
aw12345
Swapping axles and stretching the wheelbase isn't all that hard.
Especially YJ's are easy to do. Outboard the spring hangers upfront,move the shackes in front of the frame for a nice stretch use XJ springs roll a HP Dana 44 or HP Dana 60 under there and button er up. Move the steering box forward some use an Astro pitman arm and things start looking pretty.
In the rear just move the shackle behind the frame roll a Dana 60 or a 14 bolt under there with the same xj springs and you get about a 109" wheelbase.
Ford shock towers all around for some 14" travel shocks and you are starting to get there. Pretty simple eh. I helped a friend do this took me about 4 hours to get everthing cut out of the way, tacked front and rear bumpers tacked all the hangers, mounted the axles and had it sitting on it's on weight. Couple of weekends later welded everything up, flexed it and then welded all four Ford shock towers and shock tabs on the axles.
Since then my bud pretty much figured his steering out and it looks pretty good to me.
aw12345 is offline
post #6 of 10 Old 12-27-2011, 07:39 PM
foggybottombob
This is the thread about my Rear Dana 60 I put on my CJ7
http://www.jeepforum.com/forum/f8/re...build-1194375/
The rear Dana 60-2 with an Eaton E-locker installed.
foggybottombob is offline
post #7 of 10 Old 12-27-2011, 08:05 PM
jason m
Nothing but the facts
jason m's Avatar
My 14 bolt build that I did 7 years ago.
That last Pic is when I pulled it out for the first time, man i wish my iroks had that much tread left.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #8 of 10 Old 12-27-2011, 08:11 PM
jason m
jason m's Avatar
Narrowed my Rockwells. Took 7"s off the long side tube and had to make my own line up pucks and bars.
Jason.
jason m is offline
post #9 of 10 Old 12-27-2011, 08:17 PM
jason m
jason m's Avatar
A friends HP 60 build with all custom brackets and truss, I allways hand fab all my own brackets and tabs. I can't see buying them, plus its nice to say you built everything.
I can answer any questions about any of the axle's I posted, there just so many axle builds Ive done I allways forget to take detailed Pics. but I remember everything about them.
Oh if this don't fit the MO of the OP post then Mods please delete.
Jason.
jason m is offline
post #10 of 10 Old 12-27-2011, 08:37 PM
kw89425
Nice
86 cj7 496 powered 465/205 ton axles 38.5 boggers
kw89425 is offline
