Air shock tech - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Advanced Jeep Tech > Air shock tech
Savvy/Currie Aluminum Control ArmsROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO December Specials at Jeephut.com
Unread 08-21-2014, 03:14 PM   #1
aw12345
Air shock tech
This is a interesting topic since these things can have some funny behavior.
My buggy wich is still in the building stages, behaved pretty well with only about 2-3" of shaft showing. Then I had the idea to get more belly height so added some nitrogen. Now this thing does some serious leaning. Seen this on a friend's XJ also, as soon as he let some nitrogen out it behaved a lot better.
Question is does adding shock oil improve this situation, don't really want to fudge with antirocks if I don't have too.
You got any input on this Jason M, I know you run air shocks on your rig.
Thanks in advance
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 08-21-2014, 05:15 PM   #2
jason m
your ad here...
jason m's Avatar
Hey Art, suspensions are not my strong side but shocks from being around them in friends builds and of course my jeep I understand them, kinda lol.
I had set my rear shocks at 150 psi and I think a tea spoon of oil. The oil was in there when I got them from my friend. I had to bump my charge up 15 more psi. When I started I had two inch's of chrome but would bottom out just driving around the yard.
So now I'm happy with them not bottoming out but I was told to keep the the same two inch up travel I planed on instead of adding gas I should of added more oil as you can't compress a liquid.
Now maybe Blane or impead can jump in and we can all learn something as again this not my strong point only my experience with them.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt....
jason m is offline   Reply With Quote Quick reply to this message
Unread 08-21-2014, 05:46 PM   #3
aw12345
Now maybe Blane or impead can jump in and we can all learn something as again this not my strong point only my experience with them.Jason.
They do seem to behave a lot better with about 2" of shaft showing. With 5-6 " of shaft showing the ride is funky to say the least. If that's what it takes, I'' just redo the upper mounts.
Unread 08-21-2014, 06:42 PM   #4
jason m
your ad here...
jason m's Avatar
Building several buggy's prior to doing my rear steer conversation we always had around two inch's of rod for ride height. The idea was/is to have more down travel than up as there is no ride quality needed. But again when it came to shocks Sean my good friend did that end. I was the build the axles, bend the tube, mostly design the chassis and weld it type of guy, lol.
Jason.
Unread 08-21-2014, 07:15 PM   #5
aw12345
Jason.
Just talked on the phone to a guy that bought my locker yesterday.
He had his on offroad fab shop in North Cal and he has built about 12 rigs with airshocks and his answer is pretty much like yours, No more than 2-3" of shaft showing at ride height. As low a nitrogen presure as possible and that's it. That should give the best compromise. So I have a little bracket fabbing to do. At 115" wheelbase the thing needs a bit of belly height. Nice to have a fairly definitive answer, so I know where to go with it. Thanks for your reply Jason.
