87 wagoneer axles on a cj7 - JeepForum.com
post #1 of 29 Old 01-20-2013, 01:09 PM Thread Starter
rockvillage
1979 CJ7
Cj 87 wagoneer axles on a cj7
I have the front and rear axle from an 87 wagoneer. I welded on an outboard spring kit. My questions are:
1. Can I use the 2" front and 2 1/2" cj7 springs? (2"lift)
2. I belive they are 3" tubes, I need to find U-bolts and Spring plates, where would I find them. The local Spring shop will make the u-bolts, but says I need to make the spring plates and sugested 1/2" steel.
Thanks,
rockvillage is offline
post #2 of 29 Old 01-21-2013, 06:59 AM
SLADE
What transfer case are you running?
87 Wagoneers are driverside drop...
CJ's are Pass. side drop....
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #3 of 29 Old 01-21-2013, 03:38 PM Thread Starter
rockvillage
1979 CJ7
Dana 300
post #4 of 29 Old 01-21-2013, 03:40 PM
BriansCJ
1994 XJ Cherokee
I'd order the spring plates from ruffstuff.
Youre going to have to do something about the front axle/transfercase
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #5 of 29 Old 01-21-2013, 04:28 PM Thread Starter
rockvillage
1979 CJ7
What do you mean about the fron axle/transfercase?
post #6 of 29 Old 01-21-2013, 04:38 PM
SLADE
The Dana 300 is a Pass. side drop case.
An 87 Wagoneer is a Driver side drop front Dana 44.
You have to have a drive shaft conect the 2....
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #7 of 29 Old 01-21-2013, 04:59 PM Thread Starter
rockvillage
1979 CJ7
I just went and looked, you are correct, I have a problem with the front axle, OUCH! Do I have any options? I have done so much work already, kinda got me down
post #8 of 29 Old 01-21-2013, 05:33 PM
SLADE
Honestly, your easiest and most economical solution would be to sell the 87 Wagoneer 44 and get a 1979 or older Wagoneer Dana 44. The 87 will be desireable for the newer jeeps (YJ, XJ, TJ) and you should be able to get a fair price out of it. You should be able to find an 79 or older for less than you get out of the 87.
Your other option is to swap transfercases. The Dana 300 shares the same bolt pattern and spline count as the 231 cases in 6 cyl Jeeps (with exception to some early XJ's) Research compatibility and problems you'll have to address. The 231 will be longer so you have to take rear driveshaft length and angle into consideration.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #9 of 29 Old 01-22-2013, 08:55 PM
BlueRubiconrich
Rockvillage you can use a Scout2 Dana 44 front end in your CJ that's what I did.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #10 of 29 Old 01-22-2013, 09:05 PM
SLADE
Thats a good option, but the biggest problem with scout axles is the lack of caster. This can be a big problem if your not comfortable cutting off the inner "C"s and setting caster.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #11 of 29 Old 01-27-2013, 08:02 AM Thread Starter
rockvillage
1979 CJ7
Dana 44 wrong side drop solution
I purchased a set of Dana 44ís out of a wagi. It was pointed out that the pumpkin was on the driverís side, It needed it to be on the passenger side. I looked hi and low for a 79 or older one that would work. No luck. I finally went to an axle shop that cuts down wide axles for CJ use. He is going to cut the long side tube, and weld a long one on the driverís side. Switch the axles and done! While there since he is giving me a good deal I am having him change the gearing and put in lockers.
post #12 of 29 Old 01-27-2013, 10:40 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Originally Posted by rockvillage
I purchased a set of Dana 44’s out of a wagi. It was pointed out that the pumpkin was on the driver’s side, It needed it to be on the passenger side. I looked hi and low for a 79 or older one that would work. No luck. I finally went to an axle shop that cuts down wide axles for CJ use. He is going to cut the long side tube, and weld a long one on the driver’s side. Switch the axles and done! While there since he is giving me a good deal I am having him change the gearing and put in lockers.
If you are planning to do all that, and pay for it to be done, why not find a high pinion front D44? With that much work you could just grab a later Bronco front "axle" with the cast junk on it. This is what I had done for my TJ.
Mail crawling.
MisfitSeven is offline
post #13 of 29 Old 01-27-2013, 06:21 PM
SLADE
I agree.
1976-77 F100/150 will have weld on wedges, 1978-79 F150/Bronco will have cast wedges, and a 78-79 F250 Dana 44 is about as good as you can get. With the work your having done, you could use any of them. Really all your using is the center section.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #14 of 29 Old 01-29-2013, 09:30 AM
The_Eng
you can flip the dana 300 and still use the axles you have.
http://www.downeastoffroad.com/html/Flipkitinstruc.htm
The_Eng is offline
post #15 of 29 Old 01-29-2013, 01:17 PM
SLADE
You CAN, but that opens up a new can of warms with new expeinces. Fliping the 300 is not really worth the cost in my opinion.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
