84 cj prop valve rear 1/4" fitting to 3/16 adapter - JeepForum.com
post #1 of 5 Old 04-19-2013, 02:00 PM Thread Starter
cj5russ
cj5russ's Avatar
1976 CJ5
Hey guys, I have a 76 cj5 with 84 cj7 axles and brakes, I picked up a cj7 prop valve to help with the disc/drum bias, but the rear line from the prop valve looks like it should be 1/4" (with 9/16x18 male threads), I picked up an adapter for the 3/16 tube, but the flare seems to be too small on the adapter.
I found an adapter with what appears to be the correct flare on it but its male side is 9/16x20... Also found another one with correct flare but it it's male side is 7/16x24.
Here is a pic of the 9/16x18 with the wrong flare, the 7/16x24 with the correct flare, and the female end I'm trying to adapt to.
Can anyone point me in the right direction?
cj5russ is offline
post #2 of 5 Old 04-22-2013, 09:49 AM Thread Starter
cj5russ
cj5russ's Avatar
1976 CJ5
No one has adapted their 1/4" outlet on the prop valve to the rear brakes to a 3/16 brake line? I'd really like to figure this one out, but can't seem to find the correct fittings.
cj5russ is offline
post #3 of 5 Old 04-23-2013, 02:38 PM Thread Starter
cj5russ
cj5russ's Avatar
1976 CJ5
*cricket chirp* cricket chirp*
cj5russ is offline
post #4 of 5 Old 05-07-2013, 07:56 PM
hmantractors
2004 KJ Liberty
Prop valve
Does that end unscrew off the prop valve? I used my original end on a new prop valve. Did not want to fight your problem.
hmantractors is offline
post #5 of 5 Old 07-26-2013, 08:27 AM Thread Starter
cj5russ
cj5russ's Avatar
1976 CJ5
Just saw this post, ya know I'm not sure, i'll have to check that out.
cj5russ is offline
