68 CJ5 with a 289 question... - JeepForum.com
post #1 of 5 Old 08-29-2013, 09:03 PM Thread Starter
scott3483
Ok so I have a 1968 cj5 with a Ford 289 in it. The rest is stock cj5 drive train and suspension. I'm looking to use the Dana 60's and np205 from my old 79 f250 under the jeep. I was curious as to what transmission would be reliable and strong? I don't care if it's manual or auto (jeep is already a manual). I'd rather not use any spendy adapters, would rather a bolt in between the 289 and np205 but I was not sure if there is any.
Thanks,
Scott
scott3483 is offline
post #2 of 5 Old 08-29-2013, 10:04 PM
jp360cj
1977 CJ7
Do you plan on stretching the wheelbase? If not an auto will be too long for the CJ5. I would look into what transmissions were available in front of that transfer case from the factory and go from there.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #3 of 5 Old 08-29-2013, 11:07 PM Thread Starter
scott3483
I was planning on stretching the wheelbase. I will check what all the t-cases came behind. I seem to be trying to build this thing to be completely overkill. It will probably never see rocks and only be a fun trail/snow/mud rig. I just figured if I already had the parts that are that beefy, why not use them?
post #4 of 5 Old 09-01-2013, 10:15 AM
paveland
Check out Novak Adapters website. Their knowledge section is very helpful for finding out what connects to what. Good luck.
paveland is offline
post #5 of 5 Old 09-11-2013, 05:30 AM
Long&Low
1967 CJ5
A Ford T18 would be a good manual choice. The factory Ford NP435 has a 8" "adapter" hanging off the end that mates to the t-case. To get rid of that adapter / extension, your gonna need a spendy adapter cause you'll have to change out the transmissions mainshaft. I don't think you'll find an auto that'll fit well and give you enough rear driveshaft length.
Long&Low is offline
