6.0 vortec wont reach high rpms - JeepForum.com
post #1 of 25 Old 11-14-2012, 09:28 PM Thread Starter
Ripper3494
so i don't really know where to put this so i figured i'd stick it here. driving around town and nice with the throttle my engine runs fine as far as i can tell, but when i get on the gas it sputters around 5000rpms, the rev limiter is around 5500. not that this is really a huge issue in a jeep but i'd like it to run right and it seems to be loosing power as it goes up pretty badly.
im thinking fuel filter maybe... i checked fuel pressure and its right where it should be for this enine
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #2 of 25 Old 11-15-2012, 09:07 AM
TJSWJ
I have seen a few 6.0's have crank sensor issues, under load the readings go off causing the engine to miss, kinda feels like your hitting a rev limiter. Any pending codes?
TJSWJ is offline
post #3 of 25 Old 11-15-2012, 09:31 AM Thread Starter
Ripper3494
i had an 02 sensor code that always comes up, so i cleared it and did a few WOT runs and the problem happened each time i hit that rpm range, came back with no codes though
build thread:
RC vs BDS
post #4 of 25 Old 11-27-2012, 11:13 AM
themonkeyman
1987 YJ Wrangler
Are you running a VSS? I know the VSS monitors a lot more than most people realize, and ive heard of issues similar to yours being related to no VSS
themonkeyman is offline
post #5 of 25 Old 11-27-2012, 04:03 PM Thread Starter
Ripper3494
yep i have a working VSS, when it went bad before i was amazed at how much it screwed up
build thread:
RC vs BDS
post #6 of 25 Old 11-27-2012, 09:07 PM
rchase559
What are you using for an intake?
I have a friend with a 5.3 in his YJ and he was having a similar issue. The motor would get to a certain RPM and then cough out until the RPM was lowered. One day out and the trail we ended up looking at it and found that the stock intake was collapsing on itself and choking the air supply to the engine. Once he altered the intake and prevented this from happening it ran just fine all the way to the rev limiter.
rchase559 is offline
post #7 of 25 Old 11-27-2012, 09:57 PM Thread Starter
Ripper3494
im using the stock upper intake with a pvc 90 degree with a cone filter. theres no chance of it collapsing on itself that i can see
build thread:
RC vs BDS
post #8 of 25 Old 11-29-2012, 08:12 PM
53J
Could be valve float. Is this a fresh motor? if not how many miles on it?
53J is offline
post #9 of 25 Old 11-29-2012, 08:52 PM
boarderofsnow
1979 CJ5
I'd put this up on the 5.3L Jeep thread on Pirate. They'll have an answer for you in no time! Doing a 5.3L swap in my CJ5 and its insane how much solid knowledge is on that thread for troubleshooting LS motors. Just my $.02 Good luck!
J.P.
President / Co-Founder
4 Wheel to Heal
"Real Heroes don't wear capes, They wear Dog Tags!"
CHECK OUT 4 WHEEL TO HEAL
4 Wheel to Heal
Build Thread
Facebook
boarderofsnow is offline
post #10 of 25 Old 12-02-2012, 11:23 AM Thread Starter
Ripper3494
its got about 110000 on the clock i believe, but it used to get up there just fine, just in the last month it started having this problem
build thread:
RC vs BDS
post #11 of 25 Old 12-02-2012, 11:24 AM Thread Starter
Ripper3494
ill take a look over there, im always too scared to post over there lol
build thread:
RC vs BDS
post #12 of 25 Old 12-04-2012, 03:25 PM
53J
Does it sound like valve float? or is it a dead miss?
I have heard stock used 5.3 have valve float around the 5500 area... maybe you have a spring getting weak.
53J is offline
post #13 of 25 Old 12-04-2012, 04:28 PM Thread Starter
Ripper3494
i'm not sure what valve float sounds like, but my engine just like stops at a certain rpm and wont go any higher and kind of sputters there. im going to try to up my fuel pressure a little since it looks like i'm a little low
build thread:
RC vs BDS
post #14 of 25 Old 12-07-2012, 04:21 PM
jason m
Nothing but the facts
jason m's Avatar
Hey Ripper I have a chance to get a 6.0 motor and me being kinda in the dark about the motors I figure I would ask you a few qeustions.
Now the motor in question is or has been in a flood. Yes I know but ive delt with this before and had good results. But those are on the older 350's and 454's anything different I should know about.
Thanks and sorry for the Highjack.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #15 of 25 Old 12-07-2012, 05:14 PM Thread Starter
Ripper3494
Jason.
no problem. i'm by no means any sort of an expert but i know that the newer genIII engines seal much better than the older engines. if you've delt with water logged engines before i cant imagine this would be much different.
ive gotten water in my 6.0 and i did everything the same as i normally would with any other engine to get it running again
if you'd like list here's what changed from the older generation engines to the third gen engines like the 6.0
decreased rotating mass for quicker revs
decreased ring friction, yet with better oil / compression control
deeper engine skirt for increased engine rigidity for a decrease in distortion for less noise, friction, wear
six-bolt main bearing caps in lieu of two & four-bolt caps
head design increases volumetric efficiency, therefore more power at all engine speeds
quieter and more efficient valve train operation
new firing order for smoother idle and less vibration throughout the operational range
sequential fuel injection
elimination of Exhaust Gas Recirculation (most engines) by achieving a more complete burn the first time
coil-near-cylinder design; shorter plug wires for a double-hot spark
one coil per spark plug; individual cylinder timing can be tuned on the fly via the PCM and knock sensing
powerful and reliable powertrain control computer with the ability to holistically control more engine (and automatic transmission) processes than ever
throttle-by wire (most models)
all models are internally balanced without any need for balance shafts, etc.
better sealing methods at the engines covers and mating components
displacement-on-demand (DOD) that senses cruising modes and shuts down operation of cylinders for increased fuel economy (starting in some models in 2005)
same overall size as the original Small Block, offering tremendous power output for such a compact size envelope
400,000 mile longevity design
build thread:
RC vs BDS
