5.3v8 Swap for 2.5l with NP246 - JeepForum.com
post #1 of 5 Old 04-13-2012, 07:59 AM Thread Starter
JOJOJEEPS
I apologize if this has been asked before but I couldn't find anything with the search function. I have a 5.3v8 with gm 4l60e mated to the original np246 tcase and wanted to know if I would run into any geometry problems on the rear drive shaft using the np246. I'm wondering if I need to stay with the 231 that the jeep came with. Just trying to minimize the cost of the conversion since I already have the np246. Thanks
JOJOJEEPS is offline
post #2 of 5 Old 04-18-2012, 10:13 AM
Ripper3494
the 4l60e/np246 is gonna give you a short driveshaft. what i did is i went through novak and got the 3 inch thick adapator plate/output shaft for the 4l60e to mate it to the np231 also if im not mistaken the 246 is all wheel drive? which would not be a good idea for a wrangler
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #3 of 5 Old 04-19-2012, 07:36 PM
badbird17x
badbird17x's Avatar
1994 ZJ
I put a 241 in mine, behind a th350 I had to lengthen it buy using a 2wd trans and making a tcase mount. Yours is tighter but I had to do this to get close to where my 231 was in a xj chassis. 241 is cheap on eBay, and all mechanical instead of push button. Mine came from a 91 Chevy pickup.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #4 of 5 Old 04-19-2012, 07:46 PM
badbird17x
badbird17x's Avatar
1994 ZJ
Zj sorry.
Also if you haven't figured out wiring, jimsperformace does the harness with a 350 Hp tune. He's done 5 for me with zero issues
post #5 of 5 Old 04-19-2012, 09:03 PM Thread Starter
JOJOJEEPS
Thanks for your responses. For some reason I have the hardest time trying to log back in to the forum everytime. I did find out that the drive shaft would be too short if I went with the NP246. As far as I can tell its not the AWD. It has the electric actuator to engage it on the bottom. I ordered the adapter kit from Advance adapters so i can use the 231. I can't wait to get this beast running. I have a local guy that builds the wiring harnesses. This will be the first of many. I already have the motor for the second one. 1in body and 1/75 suspension lifts came in today. Shaving the motor mounts off and installing the lifts tomorrow.
yj 2.5 to tj 4.0 swap questions rusty92yj Advanced Jeep Tech 8 12-17-2012 06:10 PM
Ford 8.8 swap to yj accesories. TMSquy Advanced Jeep Tech 3 04-14-2012 01:08 AM
4.0 swap--VSS wiring RockScar Advanced Jeep Tech 4 03-05-2012 05:27 AM
4.3 tbi swap help. grover_151 Advanced Jeep Tech 8 02-14-2012 05:41 AM
different headers on v8 swap Ripper3494 Advanced Jeep Tech 11 01-12-2012 08:03 PM
