5.3 swap feeler - Page 7 - JeepForum.com
post #91 of 131 Old 02-23-2013, 05:28 PM
muddigger95
Let the fun begin.
Here, hold my beer and watch this SxxT
muddigger95 is offline
post #92 of 131 Old 02-23-2013, 07:53 PM Thread Starter
Randonexplosion
Deplorable
Randonexplosion's Avatar
did you ever figure out how to upload some pics?
Randonexplosion is online now
post #93 of 131 Old 02-23-2013, 08:21 PM
muddigger95
This one from right after the swap they don't really show anything. I'll get some pics tomorrow.
post #94 of 131 Old 02-24-2013, 04:52 PM
muddigger95
Ok, what kind of pics you want.
post #95 of 131 Old 02-24-2013, 05:37 PM
muddigger95
there is a guy on pirate that is selling a camaro oil pan for$150 on pirate under engines/trannys/t-cases for sale that will fit your 5.3. Looks like compared to my truck pan it would remove 2-2 1/2 inches.
post #96 of 131 Old 02-24-2013, 06:08 PM Thread Starter
Randonexplosion
Deplorable
That would be awesome. For budget reasons ill probably wait till its running before I get a new oil pan. Can I get a pic of your tranny mount and motor mounts?
post #97 of 131 Old 02-24-2013, 08:13 PM
muddigger95
OK here are some pics of the motor mounts. On the 3 rd pic I posted is the back side against the frame it hangs down a little.
IMG_20130224_161521_647-1.jpg   IMG_20130224_190248_908.jpg   IMG_20130224_162241_550.jpg   001-3.jpg
post #98 of 131 Old 02-24-2013, 08:25 PM
muddigger95
Here are some pics of tranny mount, remember this is a AX15 trans. What meant to say earlier, about the third pic on the post earlier about the oil pan you can see the motor mount hanging off of the frame.
post #99 of 131 Old 02-24-2013, 08:45 PM Thread Starter
Randonexplosion
Deplorable
Thanks man. It helps visualizing it all. You have the AA mounts too? I like your sign in the background. :P
post #100 of 131 Old 02-24-2013, 09:03 PM
muddigger95
I wondered if anyone would catch that.
post #101 of 131 Old 02-24-2013, 09:08 PM Thread Starter
Randonexplosion
Deplorable
Any tips on getting the engine placed ? Of course firewall clearance and hood clearance
post #102 of 131 Old 02-24-2013, 09:09 PM Thread Starter
Randonexplosion
Deplorable
That should catch the eye of any heterosexual male
post #103 of 131 Old 02-24-2013, 09:12 PM Thread Starter
Randonexplosion
Deplorable
Im gonna try to get it all in place this weekend. I have my mounts, and the tranny to t case adapter should be here by friday. Did your driveshafts fit ok?
post #104 of 131 Old 02-24-2013, 09:49 PM
muddigger95
Its a little late now for you, but before I pulled mine out I took lots of measurements of where the old engine and trans set. I then figured out how much longer the new one was then the old.I was 1 in longer then the old. I also already had my radiator and had it mounted on the grill assembly. But this is what I would do if you don't have rad. I would put your trans on your engine and set it in with the trans. Mount and/or skid plate where they belong, and see how things look underneath. Then find your engine height, with your cherrypicker. Set it where it looks good. Build cribbing underneath t oil pan and set it down slowly. Disconnect your cherry picker and see if the hood closes. If everything looks good tack the engine mounts and carefully remove the engine and trans. Then burn em in solid.
post #105 of 131 Old 02-24-2013, 09:53 PM
muddigger95
I think your auto trans is longer than stock. And I'm pretty sure you will have to change you driveline lenths . That will probably cost you $100 a piece. Have you chose a radiator yet.
