07-11-2012, 06:55 PM
#1
Ive been trying to find a 5.2 donor for awhile. I thought I'd broaden the search and start looking for 5.9's also. Either would replace my 4.0 in my 99 tj. My question about the 5.9 is arent they externally balanced and the 5.2 is internally? Point being everything I find is auto. I'm going to be switching it over to manual, and I assume the 5.9 would be balanced at the fly wheel. Rather than go through all that with taking the motor to a machine shop and pay for all the shop time, do I just want to stick with a 5.2? To me its not worth the extra power to do all that. So is my assumption right or can I just take the flex plate off, throw on a fly wheel and call it good on the 5.9 like I could on the 5.2?
07-11-2012, 08:07 PM
#2
Jeep Jedi Master
I did the swap from 5.2 to 5.9 but, this is the info I used.
What is needed for a 5.2 -> 5.9 swap?
93-95 ZJ V8
5.9 flexplate
5.9 harmonic balancer
5.9 driver's side motor mount
torque converter from 96-98 V8
96-98 ZJ V8
5.9 flexplate
Notes
You can use a spacer or washers and make the 5.2 motor mount work.
You can oval out one of the holes on the 5.9 flexplate and make a 93-95 torque converter work.
Late '95 ZJs may not need the torque converter because some of them came with '96 flexplate and torque converter.
A complete motor from a 98 5.9 ZJ will bolt right into a 96-98 V8 ZJ. Because of OBD1 and EGR, it will not bolt into a 93-95 ZJ. You will need to use the old throttle body and sensors. If you have emissions testing, you will need to use the old intake manifold and the passenger's side exhaust manifold to maintain the EGR system.
The upside to swapping a 5.9 into a 93-95 V8 ZJ is the 46RH transmission, which is stronger than the 44RE used in the 96-98s.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
07-12-2012, 02:04 PM
#3
So all I need is a harmonic balancer? It'll be a complete motor and will already have it on.
Sent from my iPhone while I shouldn't be on my iPhone.
07-12-2012, 05:21 PM
#4
Living dead mod
flex plate/flywheel and the harmonic balancer are externally weighted.
it's universal though.
07-12-2012, 08:28 PM
#5
Universal as in just order a flywheel from rock auto? Or do I need to have it balanced?
07-20-2012, 11:39 PM
#6
Buy an external balance from Mopar. It should work on a stock street motor.
http://www.summitracing.com/parts/DCC-4529110/
Bob
Currie Correctlink HD steering, 4.88 Sierra gears, 35" MTR-K, Superior Axles F/R, Bilstein 5100 shocks. JE Reel driveshafts, 4 inch Terraflex lift. Savvy Sliders. Poison Spider BFH bumper, Warn 9500 Powerplant.
07-22-2012, 04:50 PM
#7
Originally Posted by Tamatacan
Isn't any flywheel for the 5.9 made to balance it? That seems kind of steep.
07-22-2012, 07:30 PM
#8
Living dead mod
that's a pretty normal price for a magnum external balance flywheel.
http://www.summitracing.com/search/P...0/?Ns=Rank|Asc
07-23-2012, 10:59 PM
#9
Well if you have a good balance shop you can have them take the 360 stock flex plate and balance it to your flywheel on an double ended arbor. We use to do it. Some shops can't but it works. Most 360 autos had the weight on the torque converter. And yes your right. Most any 360 flywheel will have enough imbalance to spin with your crank. It won't be right on but most likely close.
08-23-2012, 11:05 PM
#10
It will never get fixed.
Mopar: You gotta pay to play.
I typically have nothing worthwhile to contribute to a thread, but I contribute anyway.
