44a center swapped with a typical dana 44 - JeepForum.com
post #1 of 4 Old 01-19-2013, 10:07 PM Thread Starter
Y0ungGunZJ
Zj 44a center swapped with a typical dana 44
those that saw this episode of xtreme 4x4 where ian combines a dana 50 and 14 bolt.
those with ZJs know the 44a.my thought is do this to a rear axle 44a and a dana 44 and use the tubes w/ brackets off the 44a and weld those tubes to the center section of the 44.
does the center of the 44 have to be from a jeep aswell to keep the tube diameter the same? i.e. out of an XJ or Tj. or can i use another 44 out of a scout or one out of another vehicle that would work.
which shafts would i need to use? the one off the regular 44?
the point of this is to see if this might be a cheaper route then buying a tab kit. i know it all depends on the local JY prices.
thanks,
-James
_______._____. << ----Mine------____.____.
//_|__l__,\____\,___------Dads>> /l __,[____],_
l_--\__\__l---\[]llllll[]| -----------l--|_|-L-OllllllllO-
(o) )-o---(o) )---o-) ) ---------(o) )-o-(o) )--o-) )
Y0ungGunZJ is offline
post #2 of 4 Old 01-20-2013, 01:18 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it's been done on a wj. mainly because he had the 44 and already had a 44a.
if you don't already have a 44a and a 44 laying around, you'd be better off just buying an 8.8 and 300$ bracket kit instead of a 300-600$ 44a and a 300-600$ 44 and add in the extra costs with the more precision work required as well as getting new gears and probably carrier for it.
ratmonkey is offline
post #3 of 4 Old 01-20-2013, 04:16 PM Thread Starter
Y0ungGunZJ
ok thanks, next time i'm at the local JY i'll ask what their prices are, and ask what they'll want for an 8.8. some places want the same for a 8.8 as a 44.
post #4 of 4 Old 01-20-2013, 04:23 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
3.73 8.8's are plentiful, 3.73 iron 44's are not.
