4.0 alternator wiring - JeepForum.com
post #1 of 3 Old 06-14-2012, 09:25 AM Thread Starter
AMC-COMMANDO
1972 C104
Installed a 93 4.0 into my 72 Jeep Commando. I need some help adapting my 72 wiring to the 93 alternator. I am using a Hesco wiring harness which has a field wire that I need to hook up. But what original wires from the Commando do I need to connect to the 93 alt? And where on the 93 alt? I have had no luck finding a wiring diagram for the 93 on the net.Really appreciate any help!!
AMC-COMMANDO is offline
post #2 of 3 Old 06-16-2012, 06:37 PM
Always2L8
1982 CJ8
I have the wiring diagram from the FSM for a 1993 XJ, Cherokee in pdf format. PM me if you're interested.
Always2L8 is offline
post #3 of 3 Old 06-20-2012, 11:05 AM
JWELK
The 72 had a separate regulator. The '93 has the regulator built into the ECM. The field wire you are referring to is the regulator wire. SOOOOOOOO on my '95 the regulator/field is pin 20 on the ECM. The other wire goes to ground.
The large output wire goes to the PDC, then to the battery. The field voltage can't be successfully measured at is a Pulse Width Modulated signal to better control the alternator. A #4 wire can be added to the alternator to run to the frame if one isn't provided.
Regards,
Jim W
JWELK is offline
YJ Vacum and Wiring??? forhiremarine Advanced Jeep Tech 2 02-20-2013 05:14 PM
Wiring a GM starter? EZCJ Advanced Jeep Tech 4 06-03-2012 03:35 AM
4.0 swap--VSS wiring RockScar Advanced Jeep Tech 4 03-05-2012 05:27 AM
yj wiring harness help!! liftedyj91 Advanced Jeep Tech 3 03-01-2012 08:21 PM
SBC to a YJ have wiring questions forhiremarine Advanced Jeep Tech 9 02-13-2012 05:30 PM
