302 w/np435 question/opinion - Page 3 - JeepForum.com
post #31 of 44 Old 03-22-2013, 06:59 PM Thread Starter
dadstoys2
1987 YJ Wrangler
Lol... yeah that is funny.
I just notched the crossmember. Actually takes stress off the front shaft and damn near was stock angle.
~Rich
87 Wrangler Ford 302
2"bodylift 5"suspension 35" bfg A/Ts
Np435 trans w/ np205
dadstoys2 is offline
post #32 of 44 Old 03-24-2013, 04:49 PM Thread Starter
dadstoys2
1987 YJ Wrangler
Motor trans & tcase are finally out.
~Rich
post #33 of 44 Old 03-25-2013, 01:55 PM
40dog
are you going to remove the tub and front clip.
Keep your nose to the wind and your eye upon the skyline
40dog is offline
post #34 of 44 Old 03-27-2013, 08:45 AM Thread Starter
dadstoys2
1987 YJ Wrangler
I dont think ill need to. Possibly a fender but I think it will be fine
~Rich
post #35 of 44 Old 03-27-2013, 08:53 AM Thread Starter
dadstoys2
1987 YJ Wrangler
~Rich
post #36 of 44 Old 04-17-2013, 07:44 PM Thread Starter
dadstoys2
1987 YJ Wrangler
So I ended up getting an np205 tcase today and bolted everything together. Total length is 36" to rear of the tcase. Original length was 41" to the rear of the 231 tcase. So it actually is 5" shorter. This should be great!
~Rich
post #37 of 44 Old 04-17-2013, 08:11 PM
SLADE
Good to hear.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #38 of 44 Old 04-23-2013, 11:11 PM Thread Starter
dadstoys2
1987 YJ Wrangler
Well I'm getting there.
~Rich
post #39 of 44 Old 05-01-2013, 12:23 PM Thread Starter
dadstoys2
1987 YJ Wrangler
Well motor and trans are in. Still have to work on mount and skid plate. Got the slave and master cylinder set up and working. Had to shorten the rod 1 1/8" but works fine.
~Rich
post #40 of 44 Old 05-03-2013, 07:54 PM Thread Starter
dadstoys2
1987 YJ Wrangler
Well made a mount today and trans is bolted in. Was able to modify the skid plate. I wish that I had the motor 1" further forward but is what it is. I need to make a mount for the np205 for some extra support. Need to modify the tcase shifter but should be pretty easy.
~Rich
post #41 of 44 Old 05-05-2013, 08:23 AM
40dog
stay the course . hang in there .i still think you should have pulled the tub to avoid all the working laying down and crawling around. lookin good .
40dog is offline
post #42 of 44 Old 05-06-2013, 12:17 PM Thread Starter
dadstoys2
1987 YJ Wrangler
Its getting there. Support mount for the tcase is done. Tcase shifter is in (had to bend down 9"). Need get yokes for the np205 and intake and carb. Manifolds need to go on and will be time to start wiring. Taking a day or two off. Tub off would of made things easier but also would of made more work too.
~Rich
post #43 of 44 Old 05-15-2013, 03:24 PM Thread Starter
dadstoys2
1987 YJ Wrangler
So for the record. I tried a set of shorty headers and they would empty right at the slave cyl. No way to use them. Truck manifolds work fine.
~Rich
post #44 of 44 Old 05-19-2013, 08:11 PM Thread Starter
dadstoys2
1987 YJ Wrangler
So im working on eliminating some wiring since no computer has been on this for ever. This is going to be carbed. Starter, alt and gauges is basically all I really need to keep.
How much if any of the wire mess next to the battery towards the passengers side. There are 2 service ports and 2 relays, pretty sure the one relay has to do with the ac that has been removed already.
~Rich
