302 w/np435 question/opinion - Page 2 - JeepForum.com
post #16 of 44 Old 03-20-2013, 03:36 PM
40dog
the np435 is directly bolted to the bw1356. i cant say if it is useable for your application.not knowing what your final stretch is or if you will stay stock in wheel base.i allways mock engine and trans/transfer up in a bare frame .block and support it then sometimes rough set the tub on .measure and ,measure make some marks for the mounting with a paint pen or soap stone.dissmantel and temp tack engine mounts in and refit.full engine trans transfer install with body on is going to be a little tricky.i believe the bell housing from a ford straight 6 300 will bolt directly to your 302 you still need the flywheel / clutch assembly .a 1inch body lift will help with bell housing clearance.dont start fitting till you have the complete assembly (engine bell housing trans and transfer).This transfer case is chain driven, and has an aluminum case. It's pretty similar to the NP208 in those respects, as well as the fact that it has the same 2.72:1 low-range ratio. Ford started using this in 1980, and discontinued its use in 1988, when it was replaced with the BW 1356.
Ford Borg Warner 1356
The 1356 was first used in 1988 or 1989, replacing the BW 1345. Like its predecessor, it's chain driven. However, it has a stronger, magnesium case.
The 1356 is available with or with out fixed yoke rear output
Keep your nose to the wind and your eye upon the skyline
40dog is offline
post #17 of 44 Old 03-20-2013, 03:41 PM
SLADE
Originally Posted by dadstoys2 View Post
So are you saying that the 1356 is married to the np435? That would in turn make usable in length right?
The measurments I gave you are from a 1356 that is married to a T18.
I am unsure if or by how much the length of the spacer/mount between the transmission and transfercase varies.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #18 of 44 Old 03-20-2013, 04:18 PM Thread Starter
dadstoys2
1987 YJ Wrangler
Just checked measurements on the jeep now....
AX15 approx 24.5" from bell to rear of trans where 231 bolts to. 231 tcase measured approx 16.5" Total would be approx 41"
Np435 bell to rear of trans is approx 17"
My math says I have 24" of tcase & whatever spacer are between the case and trans. Plus a few inches I can move the motor if needed.
BTW motor and trans are from a 86 F250 complete from fan to the rear of the trans...bell, clutch, slave ect..plus 2" body lift and 4.5" suspension
~Rich
87 Wrangler Ford 302
2"bodylift 5"suspension 35" bfg A/Ts
Np435 trans w/ np205
dadstoys2 is offline
post #19 of 44 Old 03-20-2013, 10:01 PM
dtmizx
1982 CJ7
I have been searching for the Ford hydro bell housing for about 3 weeks now, It seems this bell housing was used in a diesel app and is failing so those guys are jumping on them. I did find one on eBay but $400.00 just for the bell housing with slave cylinder bracket.
I decided to stick with my mechanical setup with a non hydro Ford bell housing.
I have a Ford 302 with a T-4 and trying to be prepared for the inevitable. I think I am going with a T-18 from a 70's CJ that will be a direct bolt up with only drive shaft mods and possible shifter relocation in the tranny tunnel.
Good luck and let us know how it turns out.
dtmizx is offline
post #20 of 44 Old 03-20-2013, 11:36 PM
jp360cj
1977 CJ7
Are you planning to get the d20 with that cj t18? Because it won't bolt up to your D300. If you want to keep the d300 then a Ford t18 would be the way to go. Can usually find then much easier and cheaper than the cj version and either will have to be adapted to your current tcase
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #21 of 44 Old 03-21-2013, 09:49 AM
40dog
the ford small block bell housings for the 289 300 302 351w DO NOT FIT ANY FORD DIESELS. diesel bell only fits 6.9 and 7.3 navistar idi style diesel. the small block bell is a dime a dozen in hydraulic style.2and 4 wheel drive trucks and vans with 300-351windsor motors will swap direct to your engine. the diesel bell has cracking issues from torque .ive tig welded these bells with success many times. go hydraulic clutch if you can. i probably have one or two sb bells in the bone yard out back.if someone is lookin for one. a good site for ford info is fordtruckenthusiast.you will find all you need for info their. many of these bells are broken during install and removial .people just cant resist drawing engine and trans together with the bell bolts or do not support the engine and trans transfer properly when dissassembling.
40dog is offline
post #22 of 44 Old 03-22-2013, 01:16 PM Thread Starter
dadstoys2
1987 YJ Wrangler
Does anyone have any measurements of the np205 and bw1356 & adapter in between the trans (np435)
Im trying to add everything up. I have a total of 41" from bell to tail of the stock driveline. Np435 is 17" to the back of the trans so l have 24" to got till I am at factory length...plus motor can be moved forward a little so I can still end up with a longer rear shaft than stock. Np205 seems to be 12-13" from what info I can find. I need a total length. Shaft sticking out of the back of the trans....not sure what length adapter is needed or available. ..
~Rich
post #23 of 44 Old 03-22-2013, 03:44 PM
mvbrady
just curious....why not adapt the AX-15 to the 302...?
AX-15 should handle a even a moderate 302 and you would have 5th gear... such a blessing for MPG and long trips.
mvbrady is offline
post #24 of 44 Old 03-22-2013, 04:18 PM
40dog
the np 205 is a great transfer all gear driven but dont forget it weighs close to 250lbs. so you need a crossmember just for the transfer exclusivly. .. Or run a 70 era 435 and 205 setup.any late 70's f150,250,350, or bronco run this from factory with a adapter to marry them.. You can get this adapter from JBG for $45-65 to run with a 4wheel drive version of the NP-435, and it can be found in a junk yard if you know where to look.This setup will work it will fit .just got to think out of the stock box.
40dog is offline
post #25 of 44 Old 03-22-2013, 04:36 PM Thread Starter
dadstoys2
1987 YJ Wrangler
http://www.fordification.com/tech/transfercase.htm
They say 138lb...
Motor and trans are out of 86 f250 90 motor.
I dont like the added weight or the 1.98 ratio but strength of it, twin stick capabilities and probably the length should work.
~Rich
post #26 of 44 Old 03-22-2013, 04:44 PM Thread Starter
dadstoys2
1987 YJ Wrangler
Granny gear in the np435 (6.68) is the decision maker... but np435 is much stronger than the ax15 (3.38or around there 1rst gear) plus my slave is bad and its the internal one.. and the adapter for the 302 is as expensive as the motor and trans cost me. Ax15 also does not get me a fixed yoke. Ect...
Over all the driveline will end up solid as a rock except the rear that I'm sure I'll break:-)
~Rich
post #27 of 44 Old 03-22-2013, 05:10 PM
40dog
check the full size bronco forum FSB they should help you with all info where to find what for what.
40dog is offline
post #28 of 44 Old 03-22-2013, 05:20 PM
40dog
david i have to apologize for not sending the xj to yj clocking template for transfer case swap you requested about a year ago.did you ever do the transfer swap.ive been going thru a divorce and have bought a new piece of property and shop since then .its around here some where.if you still want it . iwas going to scan it and add as a sticky .
40dog is offline
post #29 of 44 Old 03-22-2013, 05:50 PM Thread Starter
dadstoys2
1987 YJ Wrangler
40dog...was that to me?
My name is Rich :-)
I did do an xj case last year in my yj. I notched the skid plate and it was working fine. I put it all together with the ax15 upgraded from the ba10 but the fact that I did not get everything and do the external slave which proved to be my demise. So rather than do the same job again with the same turd 4.2 im just doing it all with the ford stuff. Once I get it done it will be worth it all.
~Rich
post #30 of 44 Old 03-22-2013, 06:44 PM
40dog
thats funny .i was going to forward another user here ( dadstoy user name. ) a clocking template for transfer swap from xj to yj . Things went a little crazy here at my place over the last year and i never sent the template.i miss took your username dadstoys2 for his. its allso funny that you did the same style swap last year to and could have used the template to. i should have made a sticky here on the forum for all to use..
40dog is offline
