3 speed auto on the column to 4? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Advanced Jeep Tech > 3 speed auto on the column to 4?
Building a Bumper?Ruffstuff Axle Simple Swap Kit!~Artec JK 1 TON SWAP~
Unread 11-10-2013, 10:13 PM   #1
dsfd722sts
1980 CJ7
Cj 3 speed auto on the column to 4?
what I want to know is, has anybody converted the cj7 (1980) 3 speed automatic column shifter to a 4 speed column shift column? or is there a replacement say out of a wagoner? doing the 4l60e swap and want to keep the column shifter. any ideas? it can't be as simple as mounting the 4 speed indicator?
also if anybody knows if they are still counting "hull" numbers?
dsfd722sts is offline   Reply With Quote
Unread 11-20-2013, 07:52 PM   #2
lar308
lar308's Avatar
You maybe able to adapt parts from a chevy "G" van collum, or just use the complete collum. I don't remember the company name, but I installed a 700r4 in my 76 Laguna. There is a company that has a kit that replaced the detent plate in the shifter. If you google installing an orver drive trans into a camaro/firebird they may have something to help. Worst case, running what you have, you won't be able to manually shift into first gear. Ron
"Snowball" 1990 YJ, 4.2, Weber, HEI, 1"bl, 3.5" superlift springs, .5" ground pounder fab boom shackles, dana 44 front, 4.10, powerlok, 4340 axles, 1 ton tierod ends, dana 44 rear, 4.10, grizzly locker, 4340 axle shafts, Tom Woods SYE & rear shaft, 35" MTR's on V5 cragars, home fabed front bumper, M8000 warn (for now, 8274 soon)
lar308 is offline   Reply With Quote
Unread 01-05-2014, 02:33 AM   #3
dsfd722sts
1980 CJ7
thank you ron, ill try the "g" column.
Unread 01-29-2014, 10:59 PM   #4
REDnBLUES
1977 CJ7
Might try here. I am also doing this with a YJ column in my CJ.
1977 CJ7 - LT1 Project
REDnBLUES is offline   Reply With Quote
