3/4 ton Dana 44 er's - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Advanced Jeep Tech > 3/4 ton Dana 44 er's
Unread 08-10-2013, 06:34 AM   #1
hydrolife1970
1983 CJ8
Cj 3/4 ton Dana 44 er's
I have a 83 Scrambler and wanting to know if the axles from a Jeep J10 will fit with no mods under it. I don't know the year of the J10.
hydrolife1970 is offline   Reply With Quote Quick reply to this message
Unread 08-10-2013, 09:23 AM   #2
jp360cj
1977 CJ7
They will fit but not without mods. And J10 axles aren't 3/4 ton, they're 1/2 ton. Nearly a foot wider, rear perches must be moved in, front springs must be outboarded. front needs to be from a 74 to 79. The back can't come from a quadratrac truck.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline   Reply With Quote Quick reply to this message
Unread 08-11-2013, 07:41 PM   #3
BlueRubiconrich
A rear replacement axle is easy just cut and weld new spring perches.
Scout Dana 44 rears work well. All front axles will need some type of mods.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline   Reply With Quote Quick reply to this message
Unread 08-18-2013, 07:39 AM   #4
hydrolife1970
1983 CJ8
Cj
Correction....Done a little more research and the vechile I'm taking the axles off to put on my CJ8 is off a 1974 J20 It has a Dana 60 in the rear and a Dana 44 in front.
Unread 08-19-2013, 02:05 PM   #5
jp360cj
1977 CJ7
As long as the rear is centered, it should be a good upgrade. Those axles are most likely 8 lug so you'll need new wheels & possibly new tires if you have 15" wheels. Most 8 lug calipers are too big for 15s without some grinding. I would look for some wheels with a lot of backspacing (like H1s) to offset some of the added width.
What tire size are you running now & what do you use the Jeep for?
