3 & 4 Link Calculators - Page 2 - JeepForum.com
post #16 of 27 Old 12-17-2011, 07:42 PM
aw12345
Originally Posted by MurdaJs View Post
So does "forward from rear axle centerline" mean from the center of the axle and axle tube (near pumkin) or straight forward from the center of the axle tube?
It mean s just what it says the center of the axle shaft/ tube
aw12345 is offline
post #17 of 27 Old 12-17-2011, 07:42 PM
MurdaJs
cool thanks.
What about the upper link 'Y' entries? Is that from the front axle?
MurdaJs is offline
post #18 of 27 Old 12-17-2011, 07:43 PM
aw12345
Everything for your rear suspension links is measured from the rear axle centerline.
This should help
aw12345 is offline
post #19 of 27 Old 12-17-2011, 07:48 PM
MurdaJs
Im doing this for a front 3 link.
For the upper link the "X" entries ask for the distance for the frame and axle end from the rear axle centerline. The "Y" entries ask for the distance from axle centerline, I assume from the front.
MurdaJs is offline
post #20 of 27 Old 12-17-2011, 07:52 PM
aw12345
In this calculator you would input stuff like it's a rear axle.
I played with the 3 link calculator and that is how it makes sense.
The Y measurement is measured from the middle of the axle or total width between the axle link mounts divided by 2.
aw12345 is offline
post #21 of 27 Old 12-17-2011, 07:57 PM
MurdaJs
Thats where i got thrown off, sometimes axle centerline is the middle of the tube; but for the upper in a three link centerline means the center, (near the middle of the pumpkin on a rear axle)
Does that sound right?
MurdaJs is offline
post #22 of 27 Old 12-17-2011, 08:05 PM
aw12345
Yes you would take half the measurement between the wheels as the center for the Y measurement. mark that with some chalk or a sharpy and measure from there for where you want to put the upper link on the axle. Your biggest challenge for the front is to make the draglink and trackbar the same length
and run those as flat as possible, but perpendicular to each other.
aw12345 is offline
post #23 of 27 Old 12-17-2011, 08:11 PM
MurdaJs
Great, thanks.
Im actually mostly done with the build, just want to plug numbers in the calc to decide on what adjustments to add.
MurdaJs is offline
post #24 of 27 Old 12-18-2011, 08:49 AM
mike_dippert
hodophobic
mike_dippert's Avatar
Shouldn't the drag link and track bar be parallel?
mike_dippert is offline
post #25 of 27 Old 12-18-2011, 09:02 AM Thread Starter
jkl
Yes, perpendicular wouldn't work out to well lol
'13 10th Anniversary Unlimited Rubi
...now parting out
jkl is offline
post #26 of 27 Old 12-18-2011, 02:45 PM
aw12345
Oops parallel, I got that one all mixed up.
aw12345 is offline
post #27 of 27 Old 12-18-2011, 06:44 PM
MurdaJs
damn, now i gotta grind off my trackbar mounts..
MurdaJs is offline
