2000 TJ 5.2 swap PCM programming - JeepForum.com
post #1 of 9 Old 03-19-2013, 08:18 PM Thread Starter
voodoo50
Ok, This one is for the Dodge Mechanic or swap guru's. Swap is done but the PCM does'nt send the ground signal for the injectors. looked online and not going that route due to all the complaints. I found I can get one from Advance Auto for 200.00...but it "needs to be programmed.
Now considering that there is nothing but engine and trans from the donor 1998 durango, is programming neccesary? I can't find anything online to confirm or deny. No emissions issues here in Fl. I'm not sure why this would be a requirement considering I confirmed the PCM issue using a PCM from a 2001 ram 1500, ran like a champ!
Looking forward to the ideas.
r/
Voodoo
I can't stop stupid, I can only slow it down....
voodoo50 is offline
post #2 of 9 Old 03-20-2013, 04:44 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
They need the vin and mileage. They're stored in the pcm.
ratmonkey is offline
post #3 of 9 Old 03-20-2013, 05:17 AM Thread Starter
voodoo50
That's sorta my point. What vin? I never had one. They won't use the jeep vin. So if I were to give them a vin with the last 6 made up and a bogus mileage would that work? More to the point....does it have to have that to work? The ram didn't match when it was in there and ran fine.
I'm just trying to figure out the actuals here. Why does the PCM require a vin? Dodge won't do the programming because it is a mod, which leaves me in a pinch.
voodoo50 is offline
post #4 of 9 Old 03-21-2013, 01:43 AM
theGiantPanda
Swap This...
theGiantPanda's Avatar
did you run a external ASD and start relay? does your ASD function correctly? are you waking up the computer to tell it that you want it to start? if it was security it would run for a second and die. I think you might be missing a signal to the computer. my hemi wouldn't start until I told the computer to wake up and make the engine run!!!
do a search, theres a few guys that have the 5.2 swaps on lock.
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #5 of 9 Old 03-21-2013, 04:32 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
It requires a truck vin and you should use your mileage.
Dodge computers just go bad when sitting around, no one knows why. As he said, it works fine with a known good computer, so he needs to get a different one.
post #6 of 9 Old 03-21-2013, 04:50 PM Thread Starter
voodoo50
Yea, did styling heck on ignition and fuel, as well as the asd. So I suppose I need to find a programmer. Does it need to be in the vehicle?
voodoo50 is offline
post #7 of 9 Old 03-21-2013, 04:50 PM Thread Starter
voodoo50
Damn iPad spell check
voodoo50 is offline
post #8 of 9 Old 03-21-2013, 07:41 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
New pcm's are programmed by the manufacturer. Even the dealer drbiii tool can't change the vin in a vehicle. It can reconcile mileage though.
The comp needs the info, but only uses the vin for security and during emissions testing.
The mileage is stored for gauge cluster use.
Don't confuse your not needing the testing in your state for the computer not needing that info to complete its start up.
The used computers obviously were already programmed from the previous vehicle.
post #9 of 9 Old 03-31-2013, 02:53 PM
greenmachine99
greenmachine99's Avatar
I just got a 99 ram 5spd pcm to put in my 99 TJ with a 5.2. Pulled it from the yard, sent it to bg Chrysler to have skim removed and my vin put in. The incorrect vin should have nothing to do with no ground to the injectors. Unless it has skim. It's an asd issue.
greenmachine99 is offline
