2.5 to 4.0 motor swap question!! - JeepForum.com
post #1 of 4 Old 11-29-2013, 04:54 PM Thread Starter
DeGusipe
Hello, I am in the process of swapping my 4 cylinder out of my 2000 jeep tj and putting in the 4.0 6 cylinder. I have everything unhooked, unbolted and pulled the 4 cylinder out with the tranny and tcase attached. I have all the new parts I need for the swap. My question is about the motor mounts. Does anyone know the exact measurement for the mounts so that I dont have to sit here and put the motor in, mark the frame, double check again and then weld them back in. If anyone has that exact measurements on how far you had to move them forward that would be very helpful. Thank you!!
DeGusipe is offline
post #2 of 4 Old 11-29-2013, 07:03 PM Thread Starter
DeGusipe
Anyone?
DeGusipe is offline
post #3 of 4 Old 11-29-2013, 07:05 PM Thread Starter
DeGusipe
Also, do i need to buy a fan for the radiator? I live in PA and this time of year it stays around 30 degrees on average. should I buy one toward the summer months?
DeGusipe is offline
post #4 of 4 Old 11-30-2013, 12:49 PM
uberxj92
1992 XJ Cherokee
You're gonna need the fan even in the winter. When sitting still she'll overheat without a fan pulling air thru the radiator. 4.0's run 200-210 anyways.
U wish I could help you with measurements
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
