1ton brakes question - JeepForum.com
post #1 of 18 Old 07-02-2013, 01:47 AM Thread Starter
bojangles808
Anyone Know What Rotors/Calipers Would Allow Me To Run 15" Rims
Axles Are D60 Front From A 89 F350
Gm 14 Bolt Rear-Will Do DBC
bojangles808 is offline
post #2 of 18 Old 07-03-2013, 11:37 PM
shelbysguns
No idea but i recommend checking out pirate 4X4 they would know if anyone would. Sorry i cant help any more than that.
shelbysguns is offline
post #3 of 18 Old 07-04-2013, 05:52 AM
rchase559
With enough grinding on the calipers and wheels with very low back spacing they will.
rchase559 is offline
post #4 of 18 Old 07-04-2013, 06:10 AM
Redneck92
Is there a reason you want to run 15s? You can fit them but it requires an *** load of grinding a very low backspacing. The low backspacing will make the one tons as wide as a football field and steering will suck. Your best bet is to run 16,16.5, or 17s. On my disc brake 14 bolt with 16s there maybe a 1/4" of clearance, I am running the bigger calipers though.
86 4Runner "The Turtle" - 22RE 5spd, duals, Dana 60, 14 Bolt SAS on jackstands
02 Tacoma - 3.4 5spd TRD
Carolina Trailblazers
Redneck92 is offline
post #5 of 18 Old 07-04-2013, 06:16 AM
Redneck92
There is a kit for the front to swap a Dana 60 over to 3/4 ton(Dana 44) stuff which will fit 15s. As for the rear the only way I know of is find the smallest gm caliper you can.
post #6 of 18 Old 07-04-2013, 07:32 AM
Jeepin72
The Dana 60 Bible has some info on grinding the calipers to fit the 15's. I am guessing you already have the meats and the wheels and don't want to sell them and/or buy new!
Jeepin72 is offline
post #7 of 18 Old 07-04-2013, 09:13 AM
jason m
Nothing but the facts
jason m's Avatar
Don't cut corners now with your build, sell your tires and get into a set of 17's or at least 16's. Now you wont have to spend extra time and money making something work.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #8 of 18 Old 07-04-2013, 11:15 AM
underpowered
Bouncin' on a Budget
underpowered's Avatar
grinding.....lots of grinding and they will work.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #9 of 18 Old 07-04-2013, 12:13 PM Thread Starter
bojangles808
Thanks Everyone. Yes, i Already Have Wheels And Tires and Was trynna Avoid Selling Them To Buy Another Set.
post #10 of 18 Old 07-04-2013, 12:16 PM
Redneck92
Might be able to trade them. Could trade for some tires for 16.5s and pick up H1s fairly cheap or trade for tires for 17s and run H2s.
post #11 of 18 Old 07-08-2013, 09:38 PM
DanZ51
Depends on the D60. Chevy calipers take a little grinding to fit, not a problem there's a lot of meat on those calipers. I ran 15x10" on my Jimmy with one tons. I don't believe the Ford D60 can be ground enough to fit 15s.
"I will always be an American Soldier"
DanZ51 is offline
post #12 of 18 Old 07-10-2013, 04:37 PM
underpowered
i am running 15 x 10's on my 79 ford D60 in my k5.
it takes alot of grinding, but you can grind enough.
post #13 of 18 Old 07-10-2013, 05:30 PM
rshbutch
I just finished grinding my ford 60 to fit 15 rims. Take your time and use paint as a witness marker. Grind and test....
rshbutch is offline
post #14 of 18 Old 07-10-2013, 09:03 PM
DanZ51
There you go. Even the big Ford calipers can be made to fit 15" rims. For those who ask why? All you have to do is check prices. 15" tires are still a bunch cheaper than 16" or 17" tires. 16.5" tires have poor bead retention (without bead locks).
DanZ51 is offline
post #15 of 18 Old 07-11-2013, 10:53 AM
mountainman74
1984 CJ8
Just grind the calipers....I've done it on a couple of my trucks...works just fine and doesnt take as long as people say...
mountainman74 is offline
