1995 Jeep Cherokee - JeepForum.com
post #1 of 7 Old 03-07-2012, 03:08 PM Thread Starter
Cannonlbz
1995 Jeep Cherokee
Hey, I'm new to the forum because I need some advice.
My 95 Cherokee has a bad rod bearing and the engine at least needs a rebuild which will run around 1500-I do not have time to do it myself
A friend of mine has a 2010 Wrangler Engine and Tranny all together that I can get.
My question, is it possible to put the Wrangler engine and tranny in my jeep or would it be too much of a custom job? Both are automatic, I am worried that the computer and wiring harnesses would be needing big changes in my jeep, as well as all of the engine and tranny mounts.
Thanks:confused
Cannonlbz is offline
post #2 of 7 Old 03-07-2012, 08:42 PM
Jason
Possible, yes, but it's not a simple remove-one and replace-with-the-other, if that's what you are asking. Fabrication would be required.
Jason is offline
post #3 of 7 Old 03-07-2012, 09:29 PM Thread Starter
Cannonlbz
I guess I'm asking if it will be around the same cost as the rebuild
post #4 of 7 Old 03-07-2012, 09:34 PM
Jason
Depends. What's the '10 motor cost? Can you do the fab required to make it fit?
Jason is offline
post #5 of 7 Old 03-07-2012, 10:01 PM Thread Starter
Cannonlbz
It's like 500 bucks from a friend who swapped it for a hemi, I don't have the time to fab
post #6 of 7 Old 03-07-2012, 10:40 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Expect to pay someone in the range of 3-5k for required fabrication, materials, and wiring.
if you can find someone who thinks they can make the ecu talk to your gauges, i doubt anyone could though.
ratmonkey is offline
post #7 of 7 Old 03-08-2012, 11:28 PM
collin9749
I hydrolocked my 98 XJs and I bought a salvage engine for 300 bucks with 80000 thousand on it and had it in that night. PLEASE PUT THE 4.0 BACK IN. Think with your dipstick, if you want more power just do the 6 to 8 kit it will still be way cheaper
collin9749 is offline
