1990 YJ engine swap. 2.5L to 4.3L - JeepForum.com
post #1 of 4 Old 11-26-2013, 09:50 PM Thread Starter
F3RG
Yj 1990 YJ engine swap. 2.5L to 4.3L
Hey guys. I have a 1990 YJ 2.5 with the ax5 5 speed. No ac, no power steering. All stock. I have a 1999 Chevy Blazer with a 4.3 that I'd like to put in the jeep in place of the 2.5L. Going to be posting as I go through this project, and any support on this from people who have done it would be greatly appreciated. The blazer is a 2wd, so i will be getting a chevy t case this week (231c). Still trying to decide what to do as far as a trans... My grandfather owns a transmission shop, so i can get whatever, just havent decided what to go with yet.... Wanting to keep it a standard.. Dont know if the ax15 or NV3550 would be easier/better..... Opinions...???
F3RG is offline
post #2 of 4 Old 12-05-2013, 04:50 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
4.3 is a solid motor, I have one in a 94 blazer, but man the FI system is a pain on these things. you will need to upgrade fuel pump, as they require alot of psi (iirc mine is 55, the newer one closer to 60) and most of the regulator and all that is inside the upper intake and has a tendancy to cause problems. Im not trying to steer ya away just sharing my experience with them, YMMV
as far as the tranny goes thats well over my head. just watch the overall length of the drivetrain
-April '14- YJoTM- June '15]
The_Goob is offline
post #3 of 4 Old 12-07-2013, 06:52 PM
TMLoftis
1978 CJ5
I'd skip the 3550 and ax15 and go with a chevy nv3500.
It's the same as the jeep nv3550 but with the bellhousing built into the transmission case and will bolt straight up the 4.3 or any chevy 4.6 or v8 engines.
The output I belive is a 32 spline that should bolt up to the 241c.
Also double check on the 241c as certain years may be drivers or passenger drop.
TMLoftis is offline
post #4 of 4 Old 12-07-2013, 07:02 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
http://www.jeepforum.com/forum/f12/s...derway-324622/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
