15" rims on Dana 60's - JeepForum.com
post #1 of 19 Old 05-25-2012, 01:53 AM Thread Starter
egodfrey
egodfrey's Avatar
Im buying 40's for the tons i have going in. They are coming with 8 lug steelies. My question is I have heard of people running 15's by trimmign the caliper brackets and stuff. Butt this also depends on the backspacing of the rims, which is 3 & 5/8 back spacing. Do you thin ill need spacers too?
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #2 of 19 Old 05-25-2012, 04:55 AM
jason m
Nothing but the facts
jason m's Avatar
I have 16" rims they clear but barely, its werd my reersteer 60 has 1/2 ton calipers and I had grind them a smig to clear.
Thats because I made the 1/2 ton braket myself and It all depends on rim offset and caliper hight.
Its tuff to say if your rims will clear or not, pop them on and try, even if there close then there fine.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #3 of 19 Old 05-25-2012, 05:06 PM
RogueFab
At that low of BS, you will probably clear your steering arms, but you may have to grind a little on the calipers or run spacers. I like small wheels too. more sidewall to absorb stuff..
RogueFab is offline
post #4 of 19 Old 06-02-2012, 09:34 PM Thread Starter
egodfrey
egodfrey's Avatar
I pretty much decided to just grind the calipers. The axles are already 69"wms so i dont want to go any wider with spacers.
egodfrey is offline
post #5 of 19 Old 07-14-2012, 02:27 AM
two_much_talk
Tj
I took a grinder to my 79 Ford 60. Didn't take long and didn't take much work. I was suprised at how little I actually had to grind off.
two_much_talk is offline
post #6 of 19 Old 07-15-2012, 05:38 AM Thread Starter
egodfrey
egodfrey's Avatar
What was the backspacing on the rims?
egodfrey is offline
post #7 of 19 Old 07-15-2012, 10:14 PM
two_much_talk
Not sure but honestly if the rim has to clear the caliper it doesn't matter if it's 3.5" or 5". I'll try to remember to get a measurement for you tomorrow night.
I'm old, call me after 8pm to remind me. 616-886-0046
post #8 of 19 Old 12-17-2012, 04:58 PM
zbd74
1980 CJ7
Not sure if it matters now, but I ground down the calipers at all four corners for clearance. The backspace on my wheels are 4.25" no problem w/ clearances, I run chevy 3/4 ton calipers w/ 8-lug outers
Slightly Modified '80 CJ7
zbd74 is offline
post #9 of 19 Old 12-18-2012, 03:54 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
2015 JK Wrangler
I've got an HPD60 sitting in my garage waiting to be built and installed, and this is one of my concerns since I've got 8 37" tires that use 15" rims. One of the local fabricators near me said that if I convert to Chevy outers I can grind the calipers to fit 15" rims, but just reading this thread it sounded like maybe a couple folks made it work with the ford brakes that come with the 60. For those of you running 15" rims on a 60, how many of you are using ford calipers and rotors?
My newest build:
Necromancer_tat is offline
post #10 of 19 Old 12-20-2012, 06:51 PM
tlcnut
I'm running Terraflex Dana 60's front and rear with 15" wheels no prob.. I had them installed in a shop several years ago and I believe they were Cadillac calipers?? Don't hold me to it but I will research it if anyone is interested..
tlcnut is offline
post #11 of 19 Old 12-22-2012, 01:16 PM
two_much_talk
Tj
post #12 of 19 Old 12-22-2012, 05:20 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
so i can run 15's on ford brakes? always heard ford brakes were bigger and could not run 15's. great news, as i just put a 79 HP 60 in my rig and thought i would have to go to larger wheels.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #13 of 19 Old 12-22-2012, 05:26 PM
Necromancer_tat
2015 JK Wrangler
Let me know how it turns out
My newest build:
post #14 of 19 Old 01-06-2013, 12:16 PM Thread Starter
egodfrey
egodfrey's Avatar
I'll know for sure, in a week or two
egodfrey is offline
post #15 of 19 Old 01-08-2013, 01:21 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
you shouldn't have to grind much at all to make it work. You need very little clearance between the rim and caliper.
Poke is offline
Keeping the front end "down"/hill climbs/Instant Center... RaggedOleMan Advanced Jeep Tech 118 07-06-2015 12:55 PM
Dana 25/27 Powr-lok tech advise needed... JordanFunk Advanced Jeep Tech 1 08-12-2012 07:19 PM
Dana 60 Rotor Rubbing RockHands Advanced Jeep Tech 4 05-31-2012 06:45 PM
Jeep knuckles on a chevy dana 44 big_o_tom Advanced Jeep Tech 11 03-27-2012 12:18 PM
