1 Ton XJ - Page 6 - JeepForum.com
post #76 of 107 Old 10-15-2011, 07:15 PM Thread Starter
jkl
Messed with the suspension brackets a little today. Cut and trimmed a piece of 2" x 1/4" angle
Then I'll tie it into some 1/4" plate that will sit on top of the ballistic brackets. I'll then weld the round coil base to that.
On the drivers side basically going to build a third leg and then tie them all together with plate like the other side
Also used a spot weld cutter and seperated the rear fenders. Hopefully I'll get them cut out tomorrow.
A friend is moving out of his storage shed and needed a place to keep his welder so I quickly volunteered my house!
'13 10th Anniversary Unlimited Rubi
...now parting out
jkl is offline
post #77 of 107 Old 10-16-2011, 01:24 PM Thread Starter
jkl
...now parting out
jkl is offline
post #78 of 107 Old 10-17-2011, 06:27 AM
NHJeep4x4
1987 YJ Wrangler
Originally Posted by jkl View Post
I'm using the same springs and similar trim- looks good!
I wonder how the ride is on those springs compared to the XJ.
Old:
2.5L, 31s
NHJeep4x4 is offline
post #79 of 107 Old 10-25-2011, 06:00 PM Thread Starter
jkl
Got the front axle pulled and fired up the welder today. Only got the driver side finished. At the FD tomorrow, so hopefully I will get done mowing early Thurs. and can finish the pass side. Looked at the leaking freeze plugs and they are worse than I thought. Since the axle it out I'm going to go ahead and replace them all. Have a deal pending on my SBC and TH350. Suppose to be picked up on Sunday and should give me enough cash to get this rolling under its own power again.
Made a third "leg" so I can offset the coil seats. Traced the ballistic bracket onto a 4" x 1/4" piece os steel and then cut it out.
And then went to town...
...now parting out
jkl is offline
post #80 of 107 Old 10-25-2011, 06:16 PM
andrewmacc
Very cool.
Front looks ultra freaking wide. Are you going to swap to SRW hubs?
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
post #81 of 107 Old 10-26-2011, 01:55 PM Thread Starter
jkl
Originally Posted by andrewmacc View Post
Very cool.
It's about 85.75" No plans to swap to SRW hubs now, maybe when I wear these tires out. I'll match the rear width with spacers.
...now parting out
jkl is offline
post #82 of 107 Old 10-26-2011, 04:41 PM
NHJeep4x4
1987 YJ Wrangler
What's the actual diameter on the 40s? I measured some 38.5 boggers at 36.5.
Old:
2.5L, 31s
post #83 of 107 Old 10-26-2011, 06:46 PM Thread Starter
jkl
About 38.5 @ 20psi
...now parting out
jkl is offline
post #84 of 107 Old 10-28-2011, 09:43 AM Thread Starter
jkl
Pass side
...now parting out
jkl is offline
post #85 of 107 Old 10-28-2011, 04:47 PM Thread Starter
jkl
Originally Posted by 95wrangler4life View Post
nice build.... will be following
Thanks!
Started cleaning up the frame to plate it and making a duct tape template
...now parting out
jkl is offline
post #86 of 107 Old 10-30-2011, 01:09 PM Thread Starter
jkl
Laid the front frame plate template out on some 1/8" steel
Still need to trim them up a bit to fit better and drill rosette holes.
...now parting out
jkl is offline
post #87 of 107 Old 11-20-2011, 06:42 PM Thread Starter
jkl
Just got done placing these orders:
Barnes 4WD - 2 DOM sleeves w/bushings, adj. upper link mount, axle link tower and frame link mounts
Liquid Iron Ind. - 2 Johnny Joints and DIY front bumper brackets
Clayton Offroad - 4 square tube inserts, 4 jam nuts and 6 bolts, washers, nuts
Also got the front axle back under the Jeep today. Shooting for front axle placement somewhere around here.
...now parting out
jkl is offline
post #88 of 107 Old 11-20-2011, 08:53 PM
andrewmacc
So is that around 3 inches of front stretch? Looks like the ticket to me.
Good to see you're keeping on this.
post #89 of 107 Old 11-21-2011, 03:02 PM Thread Starter
jkl
I think it's about 2-3. Once I get everything in place I'll measure the wheelbase and be able to figure it out. The rear is +3 now but may go to 4 if I use one of the offset spring perch holes.
...now parting out
jkl is offline
post #90 of 107 Old 11-26-2011, 10:55 AM Thread Starter
jkl
My Barnes 4WD order arrived yesterday while I was at work. My other 2 orders should be here Monday, and of course I'm on duty again
...now parting out
jkl is offline
1 ton , cherokee , xj
