1 Ton XJ - Page 5 - JeepForum.com
post #61 of 107 Old 09-28-2011, 02:53 PM Thread Starter
jkl
Originally Posted by leftlanetruckin View Post
or more accurately when time permits. Martin
I know what you mean lol
Ordered a Dana 300 adapter last night and it is suppose to be shipped this morining.
'13 10th Anniversary Unlimited Rubi
...now parting out
jkl is offline
post #62 of 107 Old 09-29-2011, 05:28 AM
shortbus-xj
Ok I have a question... what tranny are you running in it.
OVOR BISH
shortbus-xj is offline
post #63 of 107 Old 09-29-2011, 08:23 AM Thread Starter
jkl
Originally Posted by The_Blacksmith View Post
how did I not see this sooner! awesome!
Thanks!
AW4
...now parting out
jkl is offline
post #64 of 107 Old 09-29-2011, 09:06 AM
shortbus-xj
Originally Posted by jkl View Post
Thanks!
AW4
did you get it re-geared or anything, im running the same thing and just trashed mine, well I didnt my girl did Im in Afghanistan
OVOR BISH
post #65 of 107 Old 09-29-2011, 11:51 AM Thread Starter
jkl
Trans - no
Axles - yes 5.13s
...now parting out
jkl is offline
post #66 of 107 Old 09-30-2011, 02:15 PM Thread Starter
jkl
Originally Posted by GrouchyTim View Post
This thread just inspired my next build to get rolling. As soon as I find an XJ with a strong motor for cheap.
This hobby is addicting isn't it lol
Trans/transfercase adapter showed up today. Looks like I'll be busy tomorrow!
...now parting out
jkl is offline
post #67 of 107 Old 10-01-2011, 05:51 PM Thread Starter
jkl
Got some work done today, but not as much as I wanted too. Woke up this morning to a backed up septic system and had to deal with that
The adapter ring didn't quite fit right, but after sone grinding and enlarging the holes a hair it finally bolted up. Hopefully I'll get it mounted to the tran later this week.
And the big hole I cut for clearance. Found some rust in that side of the floor pan so I just hacked at it since I'm going to have to replace it.
...now parting out
jkl is offline
post #68 of 107 Old 10-01-2011, 08:10 PM
1stblack97ZJ
this is by far one of my favorite JF build threads.
how much of a budget are you working with if you don't mind me asking?
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #69 of 107 Old 10-02-2011, 08:53 AM Thread Starter
jkl
Thanks!
Im have about $5000 in it the way it sits now including the purchase of the Jeep. I'm guesstimating about another $1000 in the 3 link front, trackbar, having the driveshafts rebuilt and the sheetmetal for rear inner fenders and the hole I created for the transfercase.
...now parting out
jkl is offline
post #70 of 107 Old 10-07-2011, 01:40 PM Thread Starter
jkl
Got the transfercase installed today. The only issue is now it wont start with the key (started when I jumped the starter). I have not checked the nuetral safety switch yet, but is there anything this swap could have done to cause this?
...now parting out
jkl is offline
post #71 of 107 Old 10-09-2011, 06:39 PM Thread Starter
jkl
Got the frame stiffeners cut and fitted today. Now the fun part of preping the frame and drilling all the rosette holes begins.
...now parting out
jkl is offline
post #72 of 107 Old 10-09-2011, 07:08 PM
GrouchyTim
Is that 2x2x1/4"? Can't wait to see how you are attaching it all. This whole no frame thing is tough to get around.
'88 YJ with SOA and SYE and a bunch of custom crap from BWF in Chesapeake.
'97 XJ on 8" lift, double triangulated rear, long arm 3 link front, Eaton/60 with 5.14 gears.
GrouchyTim is offline
post #73 of 107 Old 10-09-2011, 07:30 PM Thread Starter
jkl
Each side is 5 ft. of 3x3x3/16 with 2 relief cuts for the slight rise in the frame and then notched around the rear spring hanger
...now parting out
jkl is offline
post #74 of 107 Old 10-11-2011, 02:32 AM
andrewmacc
Drilling them is going to be fun..
I need to go grab some good metal holesaws, I was trying to drill my stiffeners with bits, but they just didn't stay sharp long enough.
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
post #75 of 107 Old 10-11-2011, 08:17 AM
GrouchyTim
Make sure you use cutting oil like "Tap Magic" or something to make the bit stay sharp longer. And definately use it on a hole saw.
1 ton , cherokee , xj
