Something new. - JeepForum.com
post #1 of 18 Old 08-10-2013, 04:28 PM Thread Starter
Hotshot
Something new.
I went to the grocery store looking for a thin cut of beef to try a roll up idea I've had. Wasn't having much luck with the people at the meat counter but I found something that should work. I bought a couple packages of bottom round steak because it was the thinnest slices of beef I could find. Hope it works.
What I've done is I laid these thin pieces of beef out and spread a thin coat of jimmy dean sage sausage on top. Then I took and diced up some jalapeņo real fine and put just a little on it. Then I put a little bit of Mexican blend cheese in the center. On some I used blue cheese instead of the Mexican blend. I rolled them all up and tied the ends tight with the kind of string you use on roasts. Then the outside was lightly seasoned. I'm slow cooking these on the upper rack with charcoal and chucks of hickory. Ill report back later with some more pictures.
Hotshot is offline
post #2 of 18 Old 08-10-2013, 04:29 PM Thread Starter
Hotshot
Going on the grill.
Hotshot is offline
post #3 of 18 Old 08-10-2013, 04:46 PM Thread Starter
Hotshot
Heating up a little to quick. These things are already looking tasty.
Hotshot is offline
post #4 of 18 Old 08-10-2013, 05:04 PM Thread Starter
Hotshot
Just flipped them.
Hotshot is offline
post #5 of 18 Old 08-10-2013, 05:16 PM Thread Starter
Hotshot
I think I'll call these smoked HoHo's.
Hotshot is offline
post #6 of 18 Old 08-10-2013, 07:04 PM Thread Starter
Hotshot
Everyone here raved about these things. Personally I see some room for improvement though. I think we cooked them a few minutes to long, got to talking to a neighbor and lost focus. Like anything new it needs a little bit of tweaking . With the next batch I'll make a few using spicy sausage, and a few with pepperoni instead of sausage. Might try some different cheeses also. We normally coat what we're smoking with mustard but we forgot to do it with these. Next time.
Having trouble uploading pic's right now but ill keep trying.
Hotshot is offline
post #7 of 18 Old 08-11-2013, 08:24 AM
TSEJEEPERS
Looks good!
Did you cook the sausage ahead of time?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #8 of 18 Old 08-11-2013, 08:31 AM
flyfisher12
Making rolls are always good. I have done pretty much the same thing you did except i would sear them off in a pan and then throw in the oven covered, for a few minutes. Slow cooking such a thin piece of meat will tend to dry it out but at least you have the fat from the sausage to help with that.
If you want some really good flavor from the sausage go with some spanish chorizo or andouille.
Also if you can't seem to find the right cut of meat you can always use a sharp knife and butterfly it which will make more of a pocket but it will still work nicely. I also use skirt steak for mine which is cheap and easy to find and has a decent fat content. Just make sure you cut across the grain and it will be more tender that way.
flyfisher12 is offline
post #9 of 18 Old 08-11-2013, 11:36 AM Thread Starter
Hotshot
Originally Posted by TSEJEEPERS
Looks good!
No, the steaks were maybe 3/8" thick and the sausage was spread thin. I was sure it would cook. I checked it with a thermometer also.
Hotshot is offline
post #10 of 18 Old 08-11-2013, 11:42 AM Thread Starter
Hotshot
Thanks flyfisher. Yeah these started to dry on the outside but stayed pretty moist inside. Next time ill try coating it with mustard like I do my tri tips. That usually helps keep them moist. I was looking at the chorizo at the market and thinking that might be good, I'll have to give it a try.
Hotshot is offline
post #11 of 18 Old 08-11-2013, 11:45 AM
flyfisher12
Chorizo is good on anything!! I know this isn't grilling but i make a spicy chipotle alfredo with chorizo and chicken over penne with sun dried tomatoes that is probably my favorite pasta dish, other than maybe some basic pistachio pesto.
post #12 of 18 Old 08-11-2013, 12:24 PM Thread Starter
Hotshot
Have you tried the johnsonville chorizo brats? They're very good.
Hotshot is offline
post #13 of 18 Old 08-13-2013, 09:03 PM
CGlaser
Try spraying them with the mixture of apple cider vinegar and cooking oil.
Or
Straight apple juice. Itll keep the outside moist and add a little apple taste too it
http://www.jeepforum.com/forum/f22/98-zj-slow-build-1484672/
CGlaser is offline
post #14 of 18 Old 08-14-2013, 08:01 PM
MIjeep86
I use a 50/50 mix of apple cider vinegar and apple juice.
MIjeep86 is offline
post #15 of 18 Old 08-16-2013, 11:40 AM
THOR114
You guys make me hungry!
THOR114 is offline
smoked hoho's , smoked rollups
