Rotisserie Turkey? - JeepForum.com
post #1 of 9 Old 11-15-2012, 12:13 AM Thread Starter
Kyoseki
Inconceivable!
Kyoseki's Avatar
Rotisserie Turkey?
So, for the giving of the thanks, I may have been volunteered to cook.
I have a good sized grill (Weber Genesis S-310) with a rotisserie attachment (that I bought after a few beers and internet access).
Can we bring all of these things together and create awesomeness?
What needs to be done?
Due to lack of interest, tomorrow has been canceled
Kyoseki is offline
post #2 of 9 Old 11-15-2012, 07:08 AM
jbolty
jbolty's Avatar
Probably the most imoportant thing is to get the bird solidly held in place and tied so it does not flop around. When it starts to heat up it will want to come loose. Beyond that all the normal turkey rules apply. Brine or not. Inject or not. Dry rub or not.
I usually don't brine for this type but do inject with something. Hot wing sauce, sage butter, rum butter, ...
Does this grill have a rear mounted burner? If the heat only comes from the bottom there will be some chance of flare up and no way to use a drip pan.
jbolty is offline
post #3 of 9 Old 11-16-2012, 07:31 PM Thread Starter
Kyoseki
Inconceivable!
Kyoseki's Avatar
Shouldn't be a problem, the thing I'm trying to work out right now is whether or not I have clearance, there doesn't seem to be much space below the rotisserie spindle.
However, if I pull the grate out and pull the middle "flavorizer" bars out (kinda heat shields over the burners), I think I can get a decent sized bird in there.
Oooh, I like the sound of rum butter
Yes, the burners are full width and there are front/middle/back ones, so I can use just the rear one for indirect heat.
Kyoseki is offline
post #4 of 9 Old 11-16-2012, 11:46 PM
jbolty
jbolty's Avatar
I'm meaning back as vertical on the back wall of the grill.
like this
jbolty is offline
post #5 of 9 Old 11-17-2012, 12:25 AM Thread Starter
Kyoseki
Inconceivable!
Kyoseki's Avatar
Ah, no, I don't have that, but the rotisserie seems to be over the middle/front burners, so I think can run the rear one without worrying about flare ups.
I think I can always use the meat jacuzzi as a plan B, but you have to chop things up for that and I'd like to do a full bird
Kyoseki is offline
post #6 of 9 Old 11-17-2012, 08:38 AM
jbolty
jbolty's Avatar
A drip pan might block the heat so try it without. What's the worst that can happen? You can always stuff it in the oven. If it works you will be a happy guy.
I can't stress tieing it enough. Even of it seems secured a 12-15 # bird will start flopping on the spit once the joints get loose. Lots of butcher string and keep an eye on it.
Last though. If you care about gravy, you won't get any this way. Food for less has whole chickens on sale this week. Get a couple today and roast them in the oven for the gravy.
jbolty is offline
post #7 of 9 Old 11-21-2012, 12:43 PM
XJ99
XJ99's Avatar
2006 XK Commander
I agree about the stress on tieing it up! I've only done
small yard birds, and they can come lose. (not fun)
Use indirect heat. Keep the bird in the middle, and
kill that burner. (s) Remove the grates, and that
will give you more room.
Pork butts are good too...
Good luck, mines going in the oven! (plays it safe, likes gravy!)
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is offline
post #8 of 9 Old 11-27-2012, 07:24 AM
jbolty
jbolty's Avatar
So what happened?
jbolty is offline
post #9 of 9 Old 11-27-2012, 10:56 PM Thread Starter
Kyoseki
Inconceivable!
Kyoseki's Avatar
I cheated and used the meat jacuzzi instead
... I figure I'll practice on a few chickens first
Kyoseki is offline
