ChrisHager's Grilled Thread - Page 18 - JeepForum.com
 1Likes
post #256 of 384 Old 08-24-2013, 01:55 AM
phitmein
phitmein's Avatar
Random thought maybe .
How does the old saying about your dog go ?
"His bark, is worse than his bite "
Well, they weren't talking Q were they .
Just say'n .
phitmein is offline
post #257 of 384 Old 09-18-2013, 11:02 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Since it has been a while since I've posted, I figured I'd throw a couple pictures up from last week - the wife and I grilled up some steak! I haven't smoked anything in quite a while but hope to get back to it soon. Things have just been crazy lately which has kept me from grilling! On top of being busy, we tore out the pool and deck so I've temporarily lost my cooking area!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #258 of 384 Old 09-18-2013, 11:16 AM
CrawlingForward
Oh, damn. Now I *really* want a steak.....
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #259 of 384 Old 09-18-2013, 02:56 PM
Jim1611
Jim1611's Avatar
My favorite! You can't get a better steak than what you grille at home.
Jim1611 is offline
post #260 of 384 Old 09-18-2013, 03:01 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
These were from my fresh beef stock pile too!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #261 of 384 Old 09-24-2013, 10:17 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Chris, what do you recommend for steaks? All you have access to, on a budget, is grocery store steaks. I usually do a montreal spice, which is pretty good.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #262 of 384 Old 09-25-2013, 07:32 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
I usually do my steaks one of two ways:
1. I season with only salt and pepper right as I'm putting them on the charcoal grill. Cook medium to medium rare, remove from grill, and let sit for 5 minutes. The minimal seasoning allows you to taste the steak. I like this way because it is simple and the steak turns out well.
2. Stuffed Steak - I can't believe I don't have this recipe up. I'll type what I remember but adapt this post when I post pictures.
The original recipe called for an inch or two thick steak(s). I tried this but not only is it expensive, you have to cook the steak at a very low heat to cook all the way through. Since an hour or more cook time for a steak is a pain, I go for thinner steaks.
OK, first step is fry up a pound or so of bacon. While the bacon is cooking away, saut some diced up onions and garlic in another pan. I think I use 1 large onion and maybe 3ish cloves of garlic (we love garlic). Once this is all cooked up, crumble the bacon into a mixing bowl, add the cooked onion and garlic, and crumble in some feta cheese. Mix this all together.
Next, butterfly the steak, add a bit of salt and pepper to said steak, then cram in the stuffing from above. Depending on how this step goes, you may decide to pinch the steak closed and hold it together with some soaked toothpicks. Once everything is put together, throw the steak on the grill. You'll probably have to cook the steaks at a little lower heat since they're still so thick. Be sure to flip them as well.
Once they're done, let them rest for a few and enjoy. I find the stuffing that falls out makes for a nice topping!
Now, this recipe takes a bit longer to prepare but is well worth it. ReJeana isn't a huge meat eater but she loves when I cook this. I will say, these are very rich. The bacon along with the feta cheese will fill you up fast. When we first tried this recipe, I bought some massive steaks. We had a ton of leftovers between the two of us. The second time around, I went with thinner steaks and still had about half left. What I've found is, you'll probably only eat half as much as you think.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #263 of 384 Old 09-26-2013, 10:23 PM
snobrdrkid07
WJ for Life
I stuck with #1, turned out pretty well. I am still working out how much heat and time on the grille for the steak. I am working off of a mini Coleman campfire grille. Gets the job done but, far from ideal in heat distribution!
-Michael-
post #264 of 384 Old 09-27-2013, 07:19 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Michael, I'm disappointed you didn't share pictures with the group... Haha!
I assume the Coleman is one of the little propane type grills? What I like to do is have a hot spot to sear the steak then a cooler area to slow cook through the middle. Maybe try with high heat first then knock it down a little after you've seared the outside.
To be honest, I feel I'm still learning how much time to cook things on the grill. It's an acquired skill. It's especially hard when it's dark outside.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #265 of 384 Old 10-30-2013, 09:30 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
All this stuff looks great Chris. I am going to start with the bacon wrapped stuff brats. Keep the thread going and I will keep trying.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #266 of 384 Old 10-30-2013, 10:17 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Good luck! Remember, the more you practice, the more awesome food you have to eat!
We're doing a pretty big smoke this weekend for our birthdays (I have a twin brother). Our younger brother is coming into town. The two of us are loading up my UDS into the J-10 and heading over to my twin brother's house to smoke pork butts. Said twin is smoking a couple racks of ribs in his offset smoker. Ironically, just a touch over a year ago, the three of us did almost the same thing to break in my freshly build UDS: http://www.jeepforum.com/forum/f365/...l#post14309031
I guess we will have to make this a yearly tradition! I'll take plenty of pictures.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #267 of 384 Old 10-30-2013, 10:09 PM
phitmein
phitmein's Avatar
Sounds like fun and have a Happy Birthday .
Take pictures please .
phitmein is offline
post #268 of 384 Old 10-31-2013, 08:02 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Thanks Chris. They were great.
16 Taco
dayriesw is offline
post #269 of 384 Old 10-31-2013, 08:07 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Thanks! I will definitely take pictures!
They look awesome! Great job not burning the bacon. I still fight flareups occasionally. You really have to keep an eye on bacon!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #270 of 384 Old 10-31-2013, 09:56 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Yeah. I had to use the oven instead of the open flame due to weather here.... But next time will be flame so I can char the bun. I didn't use the peppers but everything else was awesome.
I cooked the bacon for 25-30 minutes in oven @ 400 degrees.
I wasn't sure about the pickle at first but glad once the first bite happened.
I will be trying another receipt hopefully next week. Do you have anything that is campfire friendly? I don't mind prepping it all at the house but it would have to last a couple hours in the ice chest before getting to the camp.
16 Taco
dayriesw is offline
What sides have you grilled to perfection?? 77351wcj5 BBQ & Grilling 15 10-05-2011 12:28 PM
Well, it's not grilled but... Kyoseki BBQ & Grilling 5 06-29-2011 10:54 AM
