Beef Jerky? - JeepForum.com
post #1 of 15 Old 04-20-2013, 05:26 PM Thread Starter
SDDAVE
Beef Jerky?
Making my first batch tomorrow. Bought a London Broil, had it trimmed and sliced. Sitting in some marinade, in the fridge right now.
Going to use this dehydrator we have had sitting around unused for a few years. I also have an electric smoker I can use some other time.
So from the Jerky Experts, got any tips??
SDDAVE is offline
post #2 of 15 Old 04-20-2013, 06:23 PM
jbolty
jbolty's Avatar
First time I made a batch I did it out on the porch and ended up with 10,000,000 flies inside. I wrap the whole thing in cheese cloth now.
In my experience, don't over season. Its gets pretty concentrated after it dries out.
jbolty is offline
post #3 of 15 Old 04-20-2013, 10:17 PM
TSEJEEPERS
That would suck. How did the flies taste?
Come on now we all know you tried some!
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 15 Old 04-21-2013, 09:58 AM Thread Starter
SDDAVE
So what do you do, make it in the sun? Im using a little teriyaki and black pepper.
SDDAVE is offline
post #5 of 15 Old 04-21-2013, 10:50 AM
jbolty
jbolty's Avatar
I have a $20 dehydrator from walmart. It works great, just that I originally made the mistake of using it outside which attracted every fly on earth.
Best thing is to experiment with seasoning and how long you like to marinade and how long to dry it. You can try 2-3 slices each in several marinades for different times and dry them all together.
jbolty is offline
post #6 of 15 Old 04-21-2013, 11:31 AM Thread Starter
SDDAVE
Im looking at this dehydrator "HomeTrends" is the brand, probably a $20 Wallmart one, and my smoker. Wondering if I should use the smoker? What about drippings in the dehydrator, or are there any?
SDDAVE is offline
post #7 of 15 Old 04-21-2013, 12:18 PM
wilson1010
I like a little fat in the jerky. The store bought stuff never has it probably because it can't sit on the shelf for two years, but if you try a little eye of chuck roast or similar, it will have some delicious fat and after curing, it will last months without refrigeration. Remove any gristle or connective tissue. I find it much more tasty with a little fat. London Broil is not the best choice in my opinion. Its tough and not such good flavor. If you don't want any fat, get a chuck roast, get it right about frozen, just barely, and slice it real thin with a real sharp knife. Then remove any fat (sacrilege). Or, convince your butcher to thin slice it. They don't like to do that unless they have a raw slicer on hand because they have to break down the machine and clean everything before they can use it for anything else.
Also agree 100% with taking it easy on the seasoning. Especially liquid smoke, teriyaki, and soy sauce.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #8 of 15 Old 04-21-2013, 03:09 PM
MyKeyB
London broil or top round should be fine. That's what I use. This is about the same recipe I use without the paprika. I'd give you the exact recipe but I can't find it right now.
http://allrecipes.com/recipe/docs-best-beef-jerky/
Watch the drying times, first time I tried making jerky I way over dried it and made dried beef rocks.
Rust never sleeps...
MyKeyB is offline
post #9 of 15 Old 04-21-2013, 07:54 PM
jbolty
jbolty's Avatar
If there is very much fat left on it's best to keep it in the freezer since it can go bad but it will keep a good long time after it's dried. Usually, it's not around long enough to go bad though.
jbolty is offline
post #10 of 15 Old 04-22-2013, 09:06 AM Thread Starter
SDDAVE
Ok thanks for all the tips. I decided to do it in my smoker, didn't have much confidence it the dehydrator I have, and may buy a better one down the road.
I used some left over Trader Joe's teriyaki marinade I had in the fridge and, black pepper. Used tooth picks to hang the strips from the rack.
Half cup of wood chips, and smoked at 150 degrees for 5 hours. It turned out pretty good. Im going to add some sweet next time, pineapple juice maybe.
SDDAVE is offline
post #11 of 15 Old 04-22-2013, 07:42 PM
407863
Guest
Hi SDDave- I used my dehydrator as well for making jerky. Comes out nice, but depending on the cut and the time you dry it, you gotta catch it at the right time. I found out if i over dry it is getting tough like leather. I also like a little trim of fat on it. I found here at in CA at Vallarta preslized thin cut beef jersey. If you have a good meat utter you can do that yourself, of you partially freeze it to get it harder, it's easier to cut. And before you put it on the dehydrator, take a paper napkin and put just a tab tab of olive oil on the paper towel and then wipe down themsurfacenfrom the dehydrator before you place the meat on it. That prevents it from sticking.
I think a round steak or so would work best. It has been a while since I made it, but I did one in juice like you and the other one just peppered...
So, enjoy.have a test bite now and then and try to not dehydrate it too hot, otherwise it dries out...if I remember right... Good luck and let me know how it turns out!
Thor
407863 is offline
post #12 of 15 Old 04-22-2013, 07:45 PM
407863
Guest
407863 is offline
post #13 of 15 Old 05-20-2013, 08:45 PM
slingblade
smoker jerky
I make jerky in my smoker. Smoke it for 3-4 hours so it still has some moisture, then eat some while it is still warm. Awesome. I have a traeger and the recipe I use is coffee break beef jerky. The recipe is available on the Traeger web site.
Greg
slingblade is offline
post #14 of 15 Old 05-21-2013, 06:03 PM
XJ99
XJ99's Avatar
2006 XK Commander
I use london broil when they go on sale.
Trick is to keep the thickness uniform.
Crushed red pepper:
Fresh ground pepper:
Regular:
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is offline
post #15 of 15 Old 05-21-2013, 06:08 PM
XJ99
XJ99's Avatar
2006 XK Commander
Grind up some peppers..
XJ99 is offline
