Beef Jerky - JeepForum.com
post #1 of 49 Old 01-09-2012, 06:08 PM Thread Starter
Prot
Prot's Avatar
2014 JK Wrangler
Beef Jerky
Anybody on here make their own beef jerky? What are your good and bad experiences? Equipment? Recipes? Is it possible to make a sodium free or low sodium beef jerky?
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #2 of 49 Old 01-09-2012, 11:28 PM
TSEJEEPERS
Bump on this one.
How do you do it and what machine do you use?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 49 Old 01-11-2012, 12:36 PM
TBailey
1983 CJ7
Jerky is really not hard to do at all,just a little time consuming. First you have select the correct meat. It needs to be very lean meat something like a round roast. I prefer venison for jerky. Then you have to decide how you want to slice it. If you want your finished product to tear a little easier slice it across the grain. If you like it on the chewy side slice it with the grain. I slice my meat around an 1/8" thick. If its any thicker it just takes to long to dry. Any thinner and its like eating a cracker.
Yes it is possible to make it low sodium. I really don't have a recipe for it though as I make my marinade to taste. I usually use Dales steak marinade as a base. I then will add a little liquid smoke,red and black pepper,a little cumin,a very small amount of chopped garlic,and some onion powder,and maybe a little whorstershire sauce.. If you want low sodium you would substitute some mortons tender quik instead of salt as a preservative.
As far as dehydraters a decent machine works fine for jerkey. Mine came from Academy sports. I think its made by American harvest.
TBailey is offline
post #4 of 49 Old 01-11-2012, 02:31 PM
TSEJEEPERS
Have you ever tried smoking the meat first then using the dehydrater?
post #5 of 49 Old 01-11-2012, 04:22 PM
TBailey
1983 CJ7
Yes I have but its alot more labor intensive having to build a fire to smoke some jerky for a half hour, and then move it to the dehydrater. I can't tell the difference in taste between liquid smoke and actually smoking it.
TBailey is offline
post #6 of 49 Old 01-11-2012, 04:29 PM
scottywags
I make my own Jerky all the time. I use brisket freeze for about an hour so when you go to slice it thin , it kinda holds together better. Then I mix jalapeņo, fresh chopped garlic, soy sauce, liquid smoke, worshtershereshire sauce...those are the basics...and I never follow a recipe. I will add brown sugar or ginger or whatever I feel like or have handy in the kitchen. Then dehydrate.
scottywags is offline
post #7 of 49 Old 01-11-2012, 04:31 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Sodium free/low sodium is easy - just don't add salt.
I usually go with something fairly spicy for myself (powdered habanero rub, or a chilpotle marinate) and something more sedate for her (she like teriyaki.)
I find that using beer as a base for marinade will allow greater flavour penetration, and can make for a softer jerky.
Machine? I have a gas oven - I set it to "Warm" (which is about 150-160*F,) leave the door slightly open, and monitor regularly until it gets where I want it. Meat goes on a rack like a baker's cooling rack, rack fits into a cooky sheet to catch drippings Drying time runs 4-6 hours, depending on a number of factors.
Haven't smoked meat in a long time, but used to do it the old-fashioned way - hung it on a rack next to the campfire, using oak, maple, or maybe hickory to "spice up" the fire. Usually took all day to do. (The difference? Jerky is made more or less over the heat, while smoking is done in the smoke from the fire off to the side. Both are good.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #8 of 49 Old 01-11-2012, 04:40 PM Thread Starter
Prot
Prot's Avatar
2014 JK Wrangler
I thought by not having salt or by using low salt soy sauce or worstechire sauce there might be problems with spoilage or something, hence my question.
Prot is offline
post #9 of 49 Old 01-11-2012, 04:43 PM
SuperWade2
More Money than Brains
SuperWade2's Avatar
I just made 4 pounds a week or so... Maybe unconventional, but tasty none the less
I use 93% Lean Ground Beef (could just as easy use Deer, Buffalo or other lean meat, just not much of that out here in Cali), spiced up with various stuff (http://www.amazon.com/Nesco-BJ-18-Original-Flavor-18-Pack/dp/B000UCM0P6/ref=sr_1_1?ie=UTF8&qid=1326325331&sr=8-1 plus added Smoke Salt/Habnaro/Red Pepper/Chipolte, etc) and Use the LEM Jerky Cannon that holds about 1.5 lb's at a time, then squeeze out on Dehydraytor trays for 6-8 hours. Then EaT!
P.S. The old guy in the video in NOT me!
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #10 of 49 Old 01-11-2012, 05:29 PM Thread Starter
Prot
Prot's Avatar
2014 JK Wrangler
What does that gun do? Squirt ground beef out like caulking?
Prot is offline
post #11 of 49 Old 01-11-2012, 05:31 PM
SuperWade2
SuperWade2's Avatar
Basically, yes, The video linked up there shows it in action.
2017 WK2 Overland
post #12 of 49 Old 01-11-2012, 06:27 PM Thread Starter
Prot
Prot's Avatar
2014 JK Wrangler
I watched the video just now, and it got me nauseated. That just seems wrong. Then he talks about pinching it off. Is he making beef jerky or taking a crap? Additionally, ground beef has a lot more fat in it than what jerky should have which makes it more prone to spoiling.
Prot is offline
post #13 of 49 Old 01-11-2012, 07:00 PM
TBailey
1983 CJ7
It works fine with a jerky gun as long as you use 97-99% lean ground beef. But its not the same as real jerky.
TBailey is offline
post #14 of 49 Old 01-13-2012, 10:36 AM
Mitchell420tj
I would love trying to make my own jerky, WATS the best meat u would suggest buying from the super market to make ur jerky
Mitchell420tj is offline
post #15 of 49 Old 01-13-2012, 12:14 PM
TBailey
1983 CJ7
It really doesn't matter what cut it is. It just needs to be lean. Something like a round roast works good.
TBailey is offline
What to do with a beef loin? Grimm5577 BBQ & Grilling 8 11-10-2011 01:45 PM
Beef Brisket TSEJEEPERS BBQ & Grilling 4 06-08-2011 08:34 PM
