Rock slider suggestions - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > North East USA > Maryland Jeep Forum > Rock slider suggestions
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 03-27-2012, 05:29 PM   #1
Mark0225
In the process of protecting my TJ and would like to get input on some Rock sliders for under my rocker panels. I already have diamond plate rocker panels so I do not want the type that incorporates the panels and sliders.
I have a 4" lift and 1 1/4 BL also so I want to be able to use it as a step for the wife so it needs to stick out a little. Also do not want to drill into the tub if i can help it. Toughness and functionality primary concern. Appreciate your feedback.
Mark0225 is offline   Reply With Quote Quick reply to this message
Unread 03-27-2012, 06:00 PM   #2
Toms87
1987 YJ Wrangler
http://www.jeepforum.com/forum/f9/ro.../#post11051996
With rare exception, your choice in rails is commensurate with your wheeling experience level and difficulty levels.
Those that play just a tad bit harder in difficult terrain understand the ramifications and the loss of clearance where you need it the most.
Those that don't can be well served with frame mounted rails, transfer case drops, stock control arms, no SYE's, and street tires.
Looks to me like all, or most, of the good companies out there are only making body-mounted. A to Z Fabrication, for example, makes nice rails but they are body mounted.
My advice would be to remove the diamond plate and go from there.
To give you some feedback directly answering your question, I'd go custom. That way whoever welds them up for you can keep them high, to go with your body lift, otherwise a bolt-on frame mounted rail would be 1 and 1/4" farther apart from the tub than it was meant to be.
Toms87 is offline   Reply With Quote Quick reply to this message
