Fuel Filter - JeepForum.com
post #1 of 1 Old 08-18-2014, 01:47 PM Thread Starter
Shotgun123
1987 YJ Wrangler
Fuel Filter
I am restoring a 1987 YJ Wrangler, 4.2...the carb was upgraded to a manual carb, I have a dual fuel filter on the gas line at the carb, which, I blocked off the other line....That worked for awhile, it is now leaking, where does the other line go? Or what can I do to replace with a single line filter? I tried a single line once and it leaked really bad, could it have been that the carb was adjust at a high pressure? and if so what adjuster screw do I adjust? This Holly is a two barrel and has two adjusters on both sides , and one lg adjuster screw on the back. Any suggestion out ther with my leak?
Shotgun
Shotgun123 is offline
