Baltimore Jeeps - Page 14 - JeepForum.com
post #196 of 226 Old 04-03-2013, 06:17 PM
ilevine
2011 JK Wrangler
lets ride tomorrow afternoon!!
ilevine is offline
post #197 of 226 Old 04-05-2013, 11:17 AM
Joeyicu
Joeyicu's Avatar
I wish I could come but I work 2 to 12, and the girl needs an electric fan before I do more wheeling.
(2011 BMW X5 V8TT) {2005 WK Hemi } -1995 Ford Tbird- [1984 F250 6.9]
Joeyicu is offline
post #198 of 226 Old 04-08-2013, 02:23 PM
ilevine
2011 JK Wrangler
probably a worthwhile investment
ilevine is offline
post #199 of 226 Old 04-08-2013, 08:15 PM
Joeyicu
Joeyicu's Avatar
Its sitting in the backseat I just got wire it up, the relay setup is already there. I want to switch it so I can turn it off completely or turn it on completely, on top of my automatic setting it has currently.
Joeyicu is offline
post #200 of 226 Old 04-09-2013, 05:29 PM
boarderofsnow
1979 CJ5
I'll be running my dual fans on different settings, 1 will turn on and off from the thermostat and the other will be a switch. Each fan pulls about 30amps steady when on so make sure you utilize relays like you were talking about. Here is a diagram I developed before going to the thermostat setup I will be utilizing with the LS swap I'm doing.
J.P.
President / Co-Founder
4 Wheel to Heal
"Real Heroes don't wear capes, They wear Dog Tags!"
CHECK OUT 4 WHEEL TO HEAL
4 Wheel to Heal
Build Thread
Facebook
boarderofsnow is offline
post #201 of 226 Old 04-11-2013, 11:08 PM
Joeyicu
Joeyicu's Avatar
thanks for the diagram, but my system was already fully functioning and operational, untill the fan motor died when I sunk the girl into a water hole, so, I want the ability to switch the motor off for submersion, it may help the life of fans on the truck. I also want the ability to turn the fan to a constant on. I am also running a single fan. So the automatic system will stay in place, but I will switch the ground to that system to disable it on command, for water crossing. Next I will wire up a separate relayed system with a constant 12v supply, so I can command the fan on as I deem needed. That system will only work when I break the ground for my automatic system. Separate systems that effect each other.
Joeyicu is offline
post #202 of 226 Old 04-12-2013, 01:45 AM
davidtownsend
2006 WK
Went to the canal by Chesapeake city and took the Jeep out. There were some deep mud holes. I was on the Delaware side.
ForumRunner_20130412_034400.jpg   ForumRunner_20130412_034414.jpg   ForumRunner_20130412_034436.jpg   ForumRunner_20130412_034506.jpg
1994 Jeep Grand Cherokee 5.2L Limited
2006 Jeep Grand Cherokee Overland 5.7L Hemi
davidtownsend is offline
post #203 of 226 Old 04-12-2013, 11:28 AM
ilevine
2011 JK Wrangler
anyone have some suggestions for waterproofing my battery/fuse box?
ilevine is offline
post #204 of 226 Old 04-12-2013, 10:57 PM
Joeyicu
Joeyicu's Avatar
clear RTV does wonders for sealing stuff, the military uses it, and it should work at least on your battery terminals. May be able to use it for your fuse box to.
Joeyicu is offline
post #205 of 226 Old 04-22-2013, 05:52 PM
4LBlackMamba
any 4.0 ZJs out for salvage? this guy needs a trans with low mileage
4LBlackMamba is offline
post #206 of 226 Old 04-22-2013, 06:01 PM
boarderofsnow
1979 CJ5
Big Dogs Ice Breakers with 4 Wheel to Heal...this weekend! Come join us!
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #207 of 226 Old 04-22-2013, 06:57 PM
wlo2000
Anyone in the Annapolis area going?
wlo2000 is offline
post #208 of 226 Old 04-22-2013, 07:10 PM
boarderofsnow
1979 CJ5
Nathan and I are both in the Annapolis area and are going.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #209 of 226 Old 04-23-2013, 07:45 AM
dukie564
dukie564's Avatar
1995 XJ Cherokee
the 42RE is a POS. Swap an AW4 in yo
http://www.jeepforum.com/forum/f13/a...dii-zj-382739/
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #210 of 226 Old 04-23-2013, 10:36 PM
wlo2000
Why havent we met up to wheel yet if youre so close!?
wlo2000 is offline
