What is this worth - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > North East USA > New Jersey Jeep Forum > What is this worth
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 03-04-2014, 08:41 PM   #1
Bigmike84
What is this worth
I want a jeep, but need to sell my truck first. I have been looking and wow these keep there value. Saw one driving down the road and contacted seller. It's an 02 wrangler sport 4.0.
So I checked it out and appeared in good shape. Needs new soft top and windshield. Minimal rust and frame appeared in good shape. When shifting into and out of 4wd it to a couple try's to engage. Owner says engine only has 78000 miles but clock reads 222,000. Replaced a few years prior Does not look as if was beaten. Said daughter drive it for eight years and many trips to North Carolina where she was at school. With that said what would be a good deal on this or should I pass. It's bone stock. I would like bigger tires and a lift and other minor things. It won't be a dd but will use in bad weather and warm weather
Bigmike84 is offline   Reply With Quote Quick reply to this message
Unread 03-06-2014, 08:49 AM   #2
Reskar
2015 JK Wrangler
Did you check for rust on the frame and dents in the skid plates? Assuming you did but just wanted to check.
Reskar is offline   Reply With Quote Quick reply to this message
Unread 03-07-2014, 10:06 AM   #3
Bigmike84
I did. I could feel som rust when I stuck my finger in frame but I did not see any on outside. My concern was mileage. When I test drove it he did not want me to bring to a mechanic. I don't know much about engines so was not to sure what to listen for. Drove fine. Only problem was it took a couple tries to get in and out of 4wd. There was a small oil leak and I noticed the oil to be a dark black. I change oil in my own vehicles and it never looked that dark. When talking about it his stories about maintaining it and who drove it did not appear truthful. It had 222000 miles on clOck but said engine was replaced and has about 78000 miles but he had no paperwork on that. Not having the knowledge of jeeps or engines I passed.
Unread 03-07-2014, 10:17 AM   #4
crouse11c
Well first run a blue book take off about 20% for the mileage being off. I don't care if the engine has been swapped. When this happens ppl rig stuff up and make it harder to fix later. Second lift, tires cost Ali of money and most of the time you will not get your money back. Unless you know how to do yourself I think you will find a better deal with it already lifted. contact a local garage that fixes jeep they rob know 5-10 ppl selling one that they work on, this way you know a professional looked at it also.
crouse11c is offline   Reply With Quote Quick reply to this message
Unread 03-07-2014, 11:06 AM   #5
Bigmike84
Thank
