Solo Run > Reed Rd Trails, Jackson NJ - Page 21 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > North East USA > New Jersey Jeep Forum > Solo Run > Reed Rd Trails, Jackson NJ
Jeep XJ Cherokee Ulitmate Sliders now available!JcrOffroad: New XJ Rear Crusader Bumpers available!NEW Billet Aluminum Hood Catches Jeep JK Wrangler Black an
Closed Thread
Unread 10-04-2011, 06:28 AM   #301
nottusyeroc
IV always wanted to follow a professional. Man your cool.
nottusyeroc is offline
Unread 10-04-2011, 06:32 AM   #302
RedZJ
Got Mud CNJ 4x4
RedZJ's Avatar
Let me know next time you go out alone..
4 of those photos are off trail in illegal areas..
Just saying. Now I will be a dick like you.
RedZJ is offline
Unread 10-04-2011, 06:38 AM   #303
RedZJ
Got Mud CNJ 4x4
RedZJ's Avatar
The photo below is hawkins pit.
A lot of Quads and dirt bikes ride back there.. and it is 110% illegal. Local PD do have ATV's and they will chase you. So unless you wanna see all of Reed Rd/Colliers Mills.
Didnt wanna piss on your little sex fest back there, but stay out of the woods in that area if you are not going to take the time to learn the area..
RedZJ is offline
Unread 10-04-2011, 06:38 AM   #304
Grimm5577
Originally Posted by RedZJ View Post
Wth do you need 4 low for?
All those hills you can do with 4hi/part time.
Nothing in that area you need 4 lo in. Just need a set of balls, and knowledge of wheeling..
I've only had the jeep 5 days, and I'm not a veteran wheeler. I don't think i was the only one that used 4lo to get over the hill.
Grimm5577 is offline
Unread 10-04-2011, 06:39 AM   #305
nottusyeroc
I wasn't out there. Ill definitely let you know when I go alone again. Your profile pic don't look to illegal. And if by me being alone means you wanna do something I'm not afraid of a puggy kid.
Unread 10-04-2011, 06:40 AM   #306
RedZJ
Got Mud CNJ 4x4
RedZJ's Avatar
Just giving some advice. Go balls out. Most of the stuff back there is safe. I dont like to use (ok, I cant use 4lo due to having no linkage) due to the fact it makes it more interesting.
Were you the green TJ?
RedZJ is offline
Unread 10-04-2011, 06:41 AM   #307
nottusyeroc
I know the area very well iv been hunting and wheeling it with my dad since I was 12
Unread 10-04-2011, 06:42 AM   #308
RedZJ
Got Mud CNJ 4x4
RedZJ's Avatar
Nope, Ill just tip off the local PD. Just saying. Learn the area before you wheel. **** like this is the reason we are having **** closed down.
Also, that photo is in a legal spot. It was a listed road in Wharton.
RedZJ is offline
Unread 10-04-2011, 06:44 AM   #309
nottusyeroc
Big man calling the pd dam I wish I was you
Unread 10-04-2011, 06:45 AM   #310
Grimm5577
I can understand your point of view, you probably know that area very well. regardless of using 4lo out there I would still like to have confidence in the truck and be able to use 4lo when needed, which is why i got the novak.
In time, I'm sure I will try being more ballsy but for now I'm still enjoying playing things safe.
I am the white TJ.
Unread 10-04-2011, 08:03 AM   #311
pumpkinXJ
Damn red, your being a dick to everyone now huh? And dont need 4lo? Your on something. Oh also dont talk about illegal wheeling, youve done your fair share. And rat to the pd? Your changing for the worse. Nothing like you used to be years ago.
Next time you guys go out ill have to join looks like I missed out.
current 99xj (5.5 on 36s)
past 98 xj (4.5 on 33s)sold 95 zj (stocker)sold
Originally Posted by -Deepskyy- View Post
If it ever happens to me, I'll just put the clutch down to the floor, and start revving the YJ up to about 3500 and then yell out "I'M SORRY I CAN'T HEAR YOU OVER THE SOUND OF AWESOME COMING FROM MY JEEP!"
pumpkinXJ is offline
Unread 10-04-2011, 11:19 AM   #312
mudboy
hate to buurst the bubble. But 4hi in anytghing other than basically snow, put's a hell of a load not only on your transmission causing the tranny temps to soar to damaging levels, knocking life off of it every time it is used, but it also puts a load on the bottom end of the motor causing premature bearing damage.. the only way to get away yusing 4 hi in any terrain that 4 wheel is needed is to have sufficient horsepower levels which noone who has posted in this thread has. Anyone want to prove me wrong?
mudboy is offline
Unread 10-04-2011, 12:09 PM   #313
nottusyeroc
So would that mean 4 lo would wear them parts down even faster?
Unread 10-04-2011, 12:40 PM   #314
pumpkinXJ
Its easier on the trans because it doesnt have to work as hard due to the low gearing.
Unread 10-04-2011, 12:45 PM   #315
cascivic
I'm guessing the theory is your not lugging the motor as much in low so you don't get as much side loading on the piston walls bearings etc
cascivic is offline
Closed Thread
