A place in South Jersey to "Pass" Inspection - JeepForum.com
post #1 of 12 Old 05-17-2010, 01:34 PM Thread Starter
timdastis
This is not for my jeep, I should be able to pass with that with stock tires
I bought a Honda Accord as a DD a few weeks back knowing it had a problem with the CEL on - I also knew it was a knock sensor so I figured it'd be an easy fix and the guy gave me a ridiculous price on the car - I didn't really care since it drove fine and got decent MPG
Well now I realized that the engine was swapped for a JDM motor and it has no knock sensor - whoever swapped it was too dumb to switch the ecu over as well so now I'm pretty much stuck
I need to pass inspection on this and at this point will gladly pay - I just need a place that will help me get around the CEL in order to test emissions, which it should pass for - I was able to clear the CEL for a few days but I failed because the emissions testing system was "not ready"
Any input would be appreciated - I'm located in Blackwood, NJ
2000 TJ Sport Yellow
4" Franken Lift | 1" Daystar BL | Rancho Shocks | Iggee Seats | Cragar Soft 8s | 35" BFG MT | Yukon 4.88s | Smittybilt XRC8 Winch | AtoZ Front Bumper | Nate 4x4 Rear | KC Daylites | more to come
timdastis is offline
post #2 of 12 Old 05-17-2010, 03:27 PM
BIGJAY
so the car is 96 an up making it obd2 easy way is to get the new computer tuned they will delete the code from it
its hard to get over with 96 an up because the light has to be off in order to pass but there is a way around it give me info on car an ill check with my guy
BIGJAY is offline
post #3 of 12 Old 05-17-2010, 06:15 PM Thread Starter
timdastis
its a 1999 Honda Accord with a f22b JDM engine
post #4 of 12 Old 05-18-2010, 05:37 AM Thread Starter
timdastis
also, I'm not sure if anyone is real familiar with the inspection process in NJ, but I took it for a second time and passed for the CEL but failed for emissions because they werent ready to be tested - now that they're ready to be tested but the CEL is on, can I go just get it retested since the CEL check passed previously?
post #5 of 12 Old 05-18-2010, 08:38 AM
tkatc
I don't think it will pass with the CEL. The readiness tests were not complete because you reset it. You can try resetting it again and then there is a process you can do so all the tests complete themselves....MAYBE you can run the process without having the CEL come on and get it passed.
If you look up readiness tests on google for your model...it may give you the driving sequence required for all your tests to be complete.
tkatc is offline
post #6 of 12 Old 05-18-2010, 11:42 AM
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
Having the CEL on is not an automatic fail (at least it wasn't under the old system, NJ just updated again a couple months ago). It depends what the CEL was on for. Certain "low priority" systems you could have one or two not ready / failed and still pass inspection. Emissions system obviously has to be functioning correctly as far as the computer knows in order to pass.
- Justin
1992 Cherokee Laredo - mostly stock, DD. 300k miles and counting
2004 Grand Cherokee Laredo - 4.7, bone stock - Wife's DD
Tru2Chevy is offline
post #7 of 12 Old 05-18-2010, 05:17 PM
ARB-XJ
pull the light?
98 4dr XJ, 6.5" RC long arm, 35" KM2's, D44's locked front & rear,4.88's, 1-ton steering, and more...
11 JK Rubicon
ARB-XJ is offline
post #8 of 12 Old 05-18-2010, 05:32 PM
3vze28
if you go back within 14 days of the first test they are only supposed to retest based upon what it failed for the first time. nothing else...
3vze28 is offline
post #9 of 12 Old 05-18-2010, 05:35 PM
dennis461
1991 XJ Cherokee
- Justin
I think the new paper work actually states, if the CEL is on, don't come a knocking.
Here is what they have posted at NJ MVS
When you start your car, a series of dashboard warning lights flash on. That’s great – as long as none of them stay on. If your Check Engine light stays lit continuously, you need to find out what’s going on ASAP. Why? For one, your car won’t pass inspection that way. But even worse, that light could be a sign of a serious engine problem that could lead to costly repairs. But listen, before you get too worried about that light…
Do some more research, I found this
I finally did it!!! Knock sensor bypass!! Woot! Woot! - Honda-Tech
dennis461 is offline
post #10 of 12 Old 05-18-2010, 05:39 PM
77j20
1977 J-Series Truck
Do they actually hook anything up to the OBD? If not then just pull the bulb out while you get it tested. If they don't hook up to your computer like they do here in cali then they should have no way of knowing.
1977 J-20 TeamRushed AMC 401, TH400, D44 front, D60 rear, 33x12.50R16.5 Mud Terrains, SOA, rear shackle flip.
77j20 is offline
post #11 of 12 Old 05-18-2010, 06:50 PM
dennis461
1991 XJ Cherokee
SOL in NJ
In NJ, they
1. look for CEL.
2. If not lit, they hook up a diagnostic tester
3. if lit, they send you away without hooking up the tester.
My Ranger needed a new instrument panel and I put the wrong one in.
There was no CEL lit, but the diagnostic tester puts a dummy signal in to test the CEL.
I failed because it would not come on during the test.
So either way, they find it.
post #12 of 12 Old 05-19-2010, 11:04 AM Thread Starter
timdastis
Originally Posted by dennis461 View Post
I've been trying this method for about 2 weeks now since its really my only chance of passing - I've tried it in about 6 different locations but have my fingers crossed that the place i tried yesterday will be successful
anyone from central or south jersey going to jeep fundraiser in north jersey for hp? gotmudnj New Jersey Jeep Forum 3 04-23-2010 11:45 AM
Local inspection in South Jersey vfrpilot North East USA 4 09-30-2008 05:55 AM
Rocks near south jersey? GodsRollerskate North East USA 13 09-12-2008 09:29 AM
South Jersey Club Skeezer North East USA 19 03-09-2008 09:02 PM
anyone in south jersey NJscott North East USA 19 01-23-2008 09:41 PM
