Can anyone help me identify DW issue - JeepForum.com
post #1 of 10 Old 05-14-2013, 03:01 PM Thread Starter
flexsaharatj
I'm in Rockland County by Mahwah NJ and can travel. i had DW and replaced a new Teraflex HD track bar, but now I have wobble when I hit a bump. Dealer said all is fine, wondering if anyone on here can help identify issues
thanks
Matt
flexsaharatj is offline
post #2 of 10 Old 05-14-2013, 03:11 PM
larjeep
Did u replace pitman arm
DO IT ALL, AND THAN SOME!
larjeep is offline
post #3 of 10 Old 05-14-2013, 03:16 PM Thread Starter
flexsaharatj
Negative
post #4 of 10 Old 05-15-2013, 08:41 AM
XTJake
ExtremeTerrain.com
XTJake's Avatar
thanks
Matt
Matt,
Other than the trackbar, what have you replaced on the Jeep? Are all your bolts tight and your bushings in good shape? It sounds to me like there may be something loose causing your bump steer.
-Zach
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
XTJake is offline
post #5 of 10 Old 05-15-2013, 09:24 AM Thread Starter
flexsaharatj
Zach
Just track bar. Shocks were swapped but that wouldn't do it. And the leveling kit was in and out
Someone on another forum mentioned bad ball joints
Ideas?
Thanks
Matt
post #6 of 10 Old 05-15-2013, 11:17 AM
MuddyJeepZJ
MuddyJeepZJ's Avatar
Make sure the track bar bolts are tight and the holes are not egged out. Have someone turn the wheel back and forth and check for movement under the Jeep in the steering components. What kind of Death Wobble are we talking about here? Do you have to pull over to the side of the road and stop to make it stop shaking? Does it only happen when you hit a bump?
2004 Jeep Wrangler Rubicon
2003 Dodge Ram 3500
MuddyJeepZJ is offline
post #7 of 10 Old 05-15-2013, 11:47 AM Thread Starter
flexsaharatj
Track bar bolts are torqued and tight, holes not egged (to the best of my knowledge) and replaced with 9/16 bolts. Death wobble occurred when I hit a bump 40-50mph full blown had to stop the jeep to make it stop shaking. After new SS, and track bar, now just a slight wobble but I believe the SS is just masking the DW.
Only happens with a bump
post #8 of 10 Old 05-15-2013, 08:34 PM
Jrdchiropractic
2009 JK Wrangler
There's an offroad shop off 287 in Oakland nj. At least it was there when I lived in wanaque. Last I saw was about a year ago.
(0|||||||0)
09 JK w/ a winch and duratracs
Just enough to get through most of the time,
get stuck sometimes, and still get home
Jrdchiropractic is offline
post #9 of 10 Old 05-15-2013, 08:35 PM Thread Starter
flexsaharatj
thanks good to know!
post #10 of 10 Old 05-16-2013, 07:19 AM
XTJake
ExtremeTerrain.com
XTJake's Avatar
Zach
Ideas?
Thanks
Matt
Very well could be the ball joints. The ones on the JK's from the factory are notoriously weak. You'll want to jack the front end up and grab the tires and try to move them up and down If you get any play in them, then they probably need replaced.
Let me know if this is the issue, if it's not I can give you a few more ideas.
-ZAch
Jake R. |
Off-Road Outfitters
XTJake is offline
