Borrowing trans jack(floor jack style) NNJ - JeepForum.com
post #1 of 8 Old 05-19-2012, 08:12 PM Thread Starter
sevenscrew
Hey guys I am going to be swapping my trans mid june and was wondering if anyone in northern new jersey has a trans jack i could borrow. Id hate to drive an hour to harbor freight for a 60 buck one. I'd only need it for maybe a week. its my first swap and my cousin (has a little experience from school) is helping me but i plan to remove the t case with the trans as 1 whole unit, and hopefully install the same way. Thanks much appreicated. im in the hopatcong area, and going to be in the boonton area to do the swap, so let me know!
1997 Limited 5.2L - SOLD
2016 2DR JK
sevenscrew is offline
post #2 of 8 Old 05-22-2012, 07:09 AM
gotmudnj
Id suggest dissassemble the tcase from trans makes it lighter and you can lift tcase off u and cousin. As for trans id say use a floor jack 2 ton and just lift and pull back no nee to go alll technically for a jeep trans not to hard to pull. Just make sure remove sensors before pulling back. Its been known for people to forget crank sensor and pull trans ad rip harness and such.
**** Happens.....
~~GOT MUD CENTRAL NEW JERSEY 4x4 ~~
gotmudnj is offline
post #3 of 8 Old 05-22-2012, 03:50 PM Thread Starter
sevenscrew
Thanks! I was told i should just remove the whole thing as 1 whole unit since there is more room to work on it once its out of the jeep. but I think i might seperate them. I was thinking about running 2 ratchet straps across both frame rails cradeling the trans & t case, and have them help me guide it down and back up (as 1 whole piece). thoughts of that?
2016 2DR JK
post #4 of 8 Old 05-23-2012, 04:15 AM
gotmudnj
Ratchet straps not safest thing to do no control over them. If i was in woods a had to i would but if able to use a floor jack id do it using jack. If need be buy jack n then return after use
**** Happens.....
gotmudnj is offline
post #5 of 8 Old 05-23-2012, 05:03 AM
jeepinsoldier10
I used ratchet straps to cradle it down. Not the easiest thing to do but get them strong enough and you can at least use them as a safety device to prevent it from falling on you. I still suggest using something else to drop the Trans and use straps as a back up
jeepinsoldier10 is offline
post #6 of 8 Old 05-23-2012, 01:46 PM Thread Starter
sevenscrew
Sorry i mean't i'd use the straps to help keep it balanced on the jack! im using a 3 ton craftsman floor jack. its a bigger jack so i should be fine. I would like to drop it as 1 unit, but i think if i have the t case attached, it wont balanace on the oil pan. anyone know if it would?
2016 2DR JK
post #7 of 8 Old 05-25-2012, 12:12 PM
gotmudnj
Do you mean trans pan?
**** Happens.....
gotmudnj is offline
post #8 of 8 Old 05-25-2012, 12:21 PM
austin6137
1990 XJ Cherokee
Trans jack bunch of sissys I tell ya, I just lay on my back under the transmission and lower it down on to my chest and the slide it off. Same deal putting it back in, I've never liked using a floor jack almost dropped a couple transmissions that way.
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
