alignment shop - JeepForum.com
post #1 of 4 Old 09-30-2012, 04:05 PM Thread Starter
Fingers
alignment shop
I am looking for a good alignment shop in south jersey in the woodbury area. I could do the alignment myself at work but I would rather pay someone that has the experience with lifted vehicles and that will adjust all 4 of my control arms. A guy I work with suggested jacks alignment in medford. Id like to find a place closer but I might just end up taking it there.
SUPPORT OUR TROOPS!
Fingers is offline
post #2 of 4 Old 10-01-2012, 03:42 AM
Technohead
Your average "alignment shop" will not be too excited about adjusting control arms. At best you would likely be charged the shop rate for a job that could very well take several hours.
-Eric
Technohead is offline
post #3 of 4 Old 10-01-2012, 05:14 PM Thread Starter
Fingers
I know, i work for a car dealer. I can do it myself if I can find out what specs to set it at with the lift.
SUPPORT OUR TROOPS!
Fingers is offline
post #4 of 4 Old 10-02-2012, 04:11 PM
Technohead
The rear should be adjusted to achieve the proper pinion angle. The correct angle depends on the type of driveshaft (double-cardan or single-cardan at the t-case). See Tom Woods web site for diagrams.
The front is a trade-off between pinion angle and caster. You cannot optimize both. I recommend 5 degrees positive caster. Any less and DW can become an issue.
If you take some measurements and do some triangle trigonometry then you can figure out how much to lengthen/shorten the control arms and avoid a trial-and-error procedure.
-Eric
transmission shop jhrebs New Jersey Jeep Forum 0 05-05-2012 05:17 PM
Reliable shop in NNJ jsmakr New Jersey Jeep Forum 10 02-27-2012 04:39 PM
Jeep friendly alignment shop. Jrob05 New Jersey Jeep Forum 1 02-08-2012 08:15 PM
Which shop for SOA lift? 94yjdude New Jersey Jeep Forum 3 06-02-2011 03:11 PM
Need a shop in NJ JerseyTeethCut5 New Jersey Jeep Forum 24 04-30-2010 04:27 PM
