tire repair? - JeepForum.com
post #1 of 1 Old 09-20-2011, 08:44 PM Thread Starter
BSaint
tire repair?
I'm looking to get a 42'' tire repaired. It has a 1.5-2 inch cut inbetween the treads, i'm wondering if it can be patched from the inside or if I need to replace the tire. I think it might be from running over a piece of glass
While checking the psi on my tires I also noticed one of my tires had a cut about 6-8'' long that follows the arch of the bead, about an inch above the bead. I'm wondering if there is anything I can do to fix this so it doesn't get worse? It doesn't leak air at all and it rides normal, but I fear that it might be weak and could give out on the highway or something. I stuck a key in it to see how deep the gash was, and it seemed to be maybe 3-4 millimeters deep, but i'm not sure how think the sidewalls are on pitbull rockers, so i don't know if thats something to be worried about or not. Any input, or anybody know any shops in the ri / mass area that does tire repair?
BSaint is offline
Need shop or someone to repair trailing arm rihemi Rhode Island Jeep Forum 4 09-12-2011 04:48 PM
