-   Rhode Island Jeep Forum (http://www.jeepforum.com/forum/f358/)
-   -   RI Powdercoating (http://www.jeepforum.com/forum/f358/ri-powdercoating-1253166/)
glap1922 08-15-2011 12:07 PM
RI Powdercoating
Does anyone know any good places in RI to get some powdercoating done? Getting a new bumper in a few weeks that will need to be either painted or coated, just trying to get an idea of what I would like to do.
NelsonATC 08-15-2011 06:35 PM
Never had any work done here, but they sponsored my kid's soccer league, so I figured I would plug them:
http://www.oceanstatehotcoat.com/
glap1922 08-15-2011 08:29 PM
Not the reasoning I expected, but it is a place to start, thanks!
Technohead 08-16-2011 04:34 AM
You might also factor how you will use the vehicle into the decision. For example, if you plan on actually wheeling it then powercoating is a waste of money. With paint you can easily touch up the scratches.
glap1922 08-17-2011 06:59 AM
It is my daily driver and will be for a couple years, so any wheeling will be kept to a minimum as I can't afford to be without a vehicle if anything were to happen. In 2-3 years I hope to relegate it to "toy" status so I can do some more serious wheeling. I will probably be going the paint route just because it is going to be significantly cheaper than powercoating, but figured I would explore my options.
If I decide to go the paint option, any suggestions on which type of paint? I've heard everything from regular black spraypaint, to bedliner, to other random things...
cvisinho 08-17-2011 10:28 AM
I painted my rockers and fender flares with rustoleum spray on bedliner.
Seems to be holding up fine so far for the DD and i sprayed them in april.
I am however going to have my bumper powdercoated at work just for the hell of it this fall.
Technohead 08-17-2011 05:12 PM
I'd steer clear of the bed liner for bumpers.
As always, the key to successful paint job is surface prep. Grind/sand all loose scale and rust, clean with acetone or similar solvent, prime, and then paint.
glap1922 08-18-2011 11:11 AM
Why would you stay clear of bedliners? I've heard a ton on prep, what types of cleaners and primers to use, but not much on what actually should be used to paint it.
Technohead 08-19-2011 12:19 PM
Because:
a.) I don't think it looks particularly good on bumpers and
b.) If you change your mind later it is a nightmare to remove.
Sjlopresto 04-27-2013 11:11 AM
Also thinking of painting my rims black?? Spray paint??... Or powder coating.. What will look better last longer
The time now is 05:13 AM.
