RI Jeep shops - JeepForum.com
post #1 of 22 Old 03-28-2011, 06:20 PM Thread Starter
bleached
RI Jeep shops
Anyone know of a good shop in RI besides Jeeps unlimited? Had a bad experience with those guys.
Thanks.
bleached is offline
post #2 of 22 Old 03-28-2011, 07:37 PM
Technohead
What are you looking to do? Buy parts, get some work done, or both?
There is a shop in Foster (I think) that claims to work on 4x4's and there is another place in Foxboro across from Patriot Place. If you are looking for replacement parts then check out Crown Automotive on RT 138 in Canton, MA.
-Eric
Technohead is offline
post #3 of 22 Old 03-28-2011, 08:38 PM Thread Starter
bleached
Thanks. Having some issues with the transfer case: getting stuck in part time and can't get back into 2hi. Already adjusted the linkage with no success.
Also need some maintenance like ball joints and tie rod ends. This is a new to me second vehicle, stock.
bleached is offline
post #4 of 22 Old 03-28-2011, 09:38 PM
Technohead
Ball joints and tie rod ends are easy DIY fixes. An OSJ member has a ball joint press with adapters for Jeep axles.
Is the t-case always hard to shift from 4wd or just sometimes? Are you sure its not due to binding in the driveline?
-Eric
post #5 of 22 Old 03-29-2011, 07:39 AM Thread Starter
bleached
I hear ya on being relatively easy fixes, but I've got a porch and laundry room that's framed and insulated, half a house that needs to be rewired and the rest of a house that needs paint. Sometimes somethings gotta give. Never done ball joints, so I'm sure it would take me quite a long time.
Anyways, I would love to take care of the t-case myself. Linkage has been adjusted and lubed up. It was incredibly hard to shift before I started messing with it. It will now shift all the way down to 4-lo, but continues to get hung up, either in full time or part time. The indicators on the dash aren't working correctly, although I do know that the lights all actually work, as they have been on at one time or another.
What do you mean by the drive line binding?
bleached is offline
post #6 of 22 Old 03-29-2011, 10:08 AM
Technohead
If you operate 4 part time on a dry surface (especially any amount of turning) then the driveline will start binding up (until the tires slip) which can make it difficult to shift the t-case.
-Eric
post #7 of 22 Old 03-29-2011, 12:37 PM Thread Starter
bleached
All shifting is difficult, even from 2hi to part time. With enough trial and error, it will go into full time. Will not come out of part time, even in a straight line back and forth.
Any other thoughts on reputable RI 4wd shops?
bleached is offline
post #8 of 22 Old 03-30-2011, 08:04 AM Thread Starter
bleached
so Jeeps Unlimited doesn't do repair anymore. They are only into parts and salvage.
Any other suggestions would be much appreciated.
thanks!
bleached is offline
post #9 of 22 Old 03-30-2011, 08:35 AM
BDS-Tech
Try http://www.the-enthusiast.com/ in Johnston, RI. He might be able to help.
phone: 517-279-2135
BDS-Tech is offline
post #10 of 22 Old 03-30-2011, 09:41 AM
Technohead
This is the place I was talking about when I said Foster. But any garage should be able to handle ball joints and TRE's without screwing it up.
Labor rates being what they are, having a shop mess around with the t-case could get expensive fast. I'd start by disconnecting the shift rod from the tab on the t-case and seeing if the shift lever (in the cab) can be move easily. I would not be surprised if the problem is with the shift lever itself. On the flip side, check if you can shift the t-case easily by hand (using the tab). I don't even have t-case linkage on my rig and just crawl under and flip the tab when I need 4wd (which sucks if you happen to be in the middle of a mud hole).
-Eric
post #11 of 22 Old 03-30-2011, 04:08 PM
GreenFour
Im in Fall River Mass be happy to help you out if needed.
Thanks
Mike
Need Rough Country Stuff Ask Me
Mass. RI. Area
GreenFour is offline
post #12 of 22 Old 03-30-2011, 04:23 PM
BDS-Tech
I would agree that the linkage sounds jacked up. Also, the OP can check that himself, without spending shop rate to check it out.
phone: 517-279-2135
BDS-Tech is offline
post #13 of 22 Old 04-03-2011, 06:45 PM Thread Starter
bleached
Thanks everyone. Will pull the linkage and shift with a big pair of pliers and see the results.
New development: Jeeps leaking tranny fluid from somewhere behind the inspection plate pretty bad. Probably torque converter or the front seal. Sucks, but it needs to go in now. not really driveable at the moment. Ill give the shops a call and see how it comes out.
thanks again.
GreenFour, you have PM.
bleached is offline
post #14 of 22 Old 04-04-2011, 09:26 AM
GreenFour
Your welcome and PM sent Back
Thanks
Mike
Mass. RI. Area
post #15 of 22 Old 04-04-2011, 09:31 AM
theskier74
Yes this is a good thread...ive dealt with a few shops and none of them actually gave me what i want. one time i went in for a tranny issue, there was no issue but i got a new starter and new tie rods. then there was a funny noise when i got it back and so i put it back in the shop and received a new alternator. but the noise is still there. im also looking for a good shop in RI
My Jeep uses the gas your hybrid saves.
Anything your car can do, our Jeeps can do better.
200k+
theskier74 is offline
jeep shops in the inland empire red02x California Jeep Forum 9 05-25-2015 10:04 AM
Charlotte, NC Jeep shops mightydog78 North Carolina Jeep Forum 11 10-07-2010 08:51 AM
Long Island Jeep Shops K_2 North East USA 8 12-22-2008 03:06 PM
baltimore, MD jeep shops ton12loc North East USA 1 07-17-2008 03:45 PM
