Need head replacement on 2012JKU - JeepForum.com
post #1 of 8 Old 11-10-2013, 10:08 AM Thread Starter
HAFICON
Well my 2012 3.6L just caught a case of bad head at 25,500, looks like it will be going to the dealer for replacement but I donít know anything about the dealers around here I really do not want some 18 year old back yard mechanic working on my Jeep. Can anyone recommend a dealer in the area that has a reliable service department? I am on Cape Cod willing to travel hour or two to the dealer if need be.
Or if you have the winning loto numbers I will just do a Diesel conversion.
Thanks
James
315/70/17 Duratrac on MB Wheels
AEV 2.5 with M.O.R.E 1" body lift
Viair 450c, ARB Air lockers,
4.88's and TNT truss.
My build thus far.
HAFICON is offline
post #2 of 8 Old 11-14-2013, 03:41 PM Thread Starter
HAFICON
Dropped my 2012 JKU off today due to the C.E.L. had been on flashing at times has a clear loss of power and when the light is flashing the Jeep will barely run but it is throwing the codes that indicate it might be affected by the head issue. I took it to Imperial Chrysler over in Mendon MA, that is about 80 miles from my house but they are the only dealer that came with positive feedback. They up front admitted that if I am having the described symptoms, and the codes I told them it has thrown then it is a head issue for sure. Imperial also said the issue in not very common but they do see it from time to time. The service advisor really made me feel comfortable with their ability to correct the issue and that the new generation head has been the solution. They have not had one come back after replacement. Premier Cape Cod which is one of the local dealers here on Cape Cod would not even look at my 2012 JKU with 26,000 miles on it unless I paid them $150. They explained even if it is a warranty item there is a charge to trouble shoot it. I know some places tell you that you will be charged it is a non-warrantable item I understand that but with only 26k miles and the check engine light o n I should not have to pay to have it looked at. Bu if you look up the reviews for this Jeep dealer then you would understand what I am talking about. There is also a Jeep dealer in Falmouth Ma here on the Cape but after talking to them they only want to sell stuff not service it.
So I will update details as I hear back from the dealer they said I would be kept informed that they are also going to get the new transmission line installed due to that recall I really do not want it installed but guess they have to. Let’s hope all goes well and someone who know what they are doing is the one working on my Wrangler.
My build thus far.
HAFICON is offline
post #3 of 8 Old 11-23-2013, 01:44 PM
RalphTomaccio
I read your first post and was going to recommend Imperial, where I bought my 2012 JKU. Then I read your second post. Please provide an update with how you made out. I suspect I will eventually need that same work done as well eventually.
RalphTomaccio is offline
post #4 of 8 Old 11-23-2013, 02:11 PM
222Doc
222Doc's Avatar
I had the left head replaced at 20k. no fee at all. the mechanic that did the work left no trace. Now on the other hand it went in for that recall on the lines to power steering/trans issue. The monkey that worked on that left oil every where, freeking mess. .
They say its not a common issue LOL??..........sure then why have the had trouble keeping up with demand for them? If you think of how FEW jeepers ever come to site like this?? FEW compared to the general public? ever got o a mini van forum? yep same thing just they do not see it till 40K+. Its like the health care act, its a work in progress
I have a bad feeling about this motors design, in the end it is disposable as well. Unless the aftermarket saves Chrysler by designing a head that has a EXHAUST MANIFOLD!
222Doc is offline
post #5 of 8 Old 11-23-2013, 03:07 PM
RalphTomaccio
Did you have Imperial do that work on the recall for the lines to thr power steering/trans issue as well or are you referring to the one on Cape Cod?
Fortunately, Imperial is only 7 miles down the road for me.
post #6 of 8 Old 11-27-2013, 05:12 PM Thread Starter
HAFICON
They have line on order I am going back to them for the line. Top notch service over there and good people. After they determined that the head was bad they did say it is really common and being the forum info I backed it up with they knew I was right, they even said they normally keep the heads in stock but due to the influx of head jobs they were out but only took them a day to get a new one.
I actually don't even need the new hose mine never had a problem rubbing and with the 1" body lift I installed it is no where close to rubbing, I would prefer to just leave it like it is but am going to discuss options with dealer like if I refuse the recall will it void any thing.
My build thus far.
HAFICON is offline
post #7 of 8 Old 11-27-2013, 07:38 PM
RalphTomaccio
I just had a little situation with Imperial. Brought it in for a noise I heard and it was a faulty exhaust connection at the engine. Apparently they had to remove the large flat plastic trim that lies on top of the engine. The following day I had to jump start my lawn tractor when I realized something didn't look right, then I saw that plastic piece missing. I called Imperial, they talked with the technician, and he realized he forgot to snap it back on and it was sitting on his work bench. He then called me and said he would bring it to my house after work and put it on so as not to inconvenience me.
Nice, huh?
post #8 of 8 Old 11-28-2013, 07:50 AM Thread Starter
HAFICON
Nice, huh?
Yes very nice.. I try not to judge people on their mistakes, just on their ability to make good on their mistakes that is what shows what kind of person they are. after my experience and your story I am thinking they are going to be the best dealer around.
My build thus far.
HAFICON is offline
