Need a good WMass 4x4 shop - JeepForum.com
post #1 of 6 Old 08-29-2012, 08:31 PM Thread Starter
bigtimmymac
Anyone know of any good 4x4 repair shops in WMass/Springfield area? After I had a suspension lift put in out in CA there is a major vibration when accelerating in the rear part of the vehicle.
Thanks
bigtimmymac is offline
post #2 of 6 Old 08-30-2012, 06:35 PM
DuffDaddy
2007 WK
There is endangered species not sure where exactly but they are in that area.......
DuffDaddy is offline
post #3 of 6 Old 09-04-2012, 12:50 PM
Elias4WDCenter
Holyoke - Todd is his name. Top notch, good tech.
Sales, Service & Installation - Suspension, Accessories, Wheels and Tires, Recovery Gear, Bumpers. WE SET UP AXLES, GEARS and LOCKERS. (And we'll work on your mother-in-law's Honda so you can wrench on your Jeep!) 978-597-8432 Mon - Thurs, 8 a.m. to 6 p.m.
Townsend, MA. Tell us Jeep Forum sent you!
Elias4WDCenter is offline
post #4 of 6 Old 09-13-2012, 09:58 AM
mattamd_xp
Just watch out for him selling you stuff you don't need and then charging an arm and a leg for what he does do. Did you get a SYE installed along with the lift? I'm local to you if you want to swing by some time and I can take a look at it for you.
99 Wrangler Project Detroit Mongrel 5.3/4l60e/Atlas HPD60/14B coilovers etc...
mattamd_xp is offline
post #5 of 6 Old 09-14-2012, 12:43 PM Thread Starter
bigtimmymac
Thanks for the response. Not exactly sure what the SYE is so bare with me. They just did a 2" lift suspension with fox shocks and 31x10.5 tires. They put on some new U joints and a steering column. They had some major vibrations after the install and couldnt figure it out for a few days. I think they did something with the differential. Had the jeep dealership check the engine and drive shaft but all were good. Even tried a new drive shaft just to make sure and no improvement so I think its the differential or rear alignment.
post #6 of 6 Old 09-14-2012, 12:50 PM
mattamd_xp
I sounds like they didn't put in a SYE (slip yoke eliminator). Some Jeeps even with 2" of lift will get vibrations because of the increase in the angle of the rear driveshaft. There is no adjustment for alignment on a stock TJ, so nothing is out there unless the Jeep was in an accident, or the lift they installed has adjustable control arms.
Local Engine Shop? Jako75 Massachusetts Jeep Forum 2 08-14-2012 07:15 AM
looking for shop in mass south coast for lift kit install youngstersTJ Massachusetts Jeep Forum 10 04-24-2012 11:54 AM
Looking for local axle shop in Southern Worcester County or Northern Rhode Island weerwolv Massachusetts Jeep Forum 9 08-17-2011 04:44 PM
Performance Shop in MA jgosse01 Massachusetts Jeep Forum 3 07-13-2011 07:18 PM
Tire Shop recommendation near Amherst MA? basso4735 Massachusetts Jeep Forum 2 01-18-2011 10:31 AM
