Mass Wheelers - Page 7 - JeepForum.com
post #91 of 115 Old 02-27-2010, 12:29 PM
BlueRubiconrich
JP magazine says the Dana 35 is a turd and I agree. little know fact:
The dana 35: AMC built this axle in 1962 then called a AMC 15. AMC sold the rights to Dana in 1985 now calling it a Dana 35.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #92 of 115 Old 03-01-2010, 08:49 AM Thread Starter
PINKANDBLACK
It is a little scarry that the little c clip is all thats holding the axleshaft. When you guys say youve seen the 35 break do you mean axle shafts or ring and pinion or what? Im definately going to carry my spare shafts with me. Now I need a friggin shift motor for the front. I guess I can get a part out of a cherokee that will fit in and work so maybe ill do that. Still unsure about exactly what the part is though.
PINKANDBLACK is offline
post #93 of 115 Old 03-01-2010, 09:24 AM Thread Starter
PINKANDBLACK
The aftermarket support for the 35 is just about as strong as anything else. OX, ARB, you name it. Rubiconrich Im going to buy you a D-35 OX locker for christmas
post #94 of 115 Old 03-01-2010, 09:24 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Originally Posted by PINKANDBLACK View Post
Im definitely going to carry my spare shafts with me.
You better carry more than that... Think of the process. Shafts usually break at the end, leaving the spline stub in the carrier and the splines buggered. You have to have tools to pull the diff cover and the carrier center pin. The broken stub has to go into the carrier to release the clip, but the buggered spline ends won't be happy to do that, so you need a 3' steel drift fed through the axle tube and a BFH to get the clip off. Then you have to pull the other axle and use the drift and BFH to get the broken part back out. Getting the 2" stub out of the axle tube may be a challenge (magnet?). Don't forget new fluid and a way to catch and store the old fluid. It will probably break in the rain on a hill too, so plan for that. You having fun yet?
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #95 of 115 Old 03-01-2010, 09:55 AM Thread Starter
PINKANDBLACK
It actually doesnt sound that bad at all. I plan to carry all the tools I need on board and extra diff fluid, I already thought of that. It kind of scares me to think about how many diffs have been drained onto the ground off the side of the trail. A rear axle shaft takes no time to get out so taking off the other side would go quick. Never thought about the 3' of steel though, that just helped me alot. This whole process would take about what 20 minutes. You guys are friggin lazy!
post #96 of 115 Old 03-01-2010, 11:03 AM
ToxicTurtle
In perfect conditions, one could accomplish it all in 20 mins.
However, as Don mentioned, do that on rocks where you can't evenly jack the Jeep, need winches to stabilize the rig, its raining, you're in mud, etc and you end up taking 2-3 hours. I have seen it happen.
Always pays to be well prepared tho.
Talk soon,
David Brill
Guilford, CT.
Burned out Land Use guru....
ToxicTurtle is offline
post #97 of 115 Old 03-01-2010, 11:26 AM Thread Starter
PINKANDBLACK
Alright I can somewhat see that
post #98 of 115 Old 03-01-2010, 06:59 PM
BlueRubiconrich
I've seen the whole axle shaft drum and wheel come right out . 3 times
Dana 35 JUNK
post #99 of 115 Old 03-02-2010, 05:34 AM Thread Starter
PINKANDBLACK
So you arent talking about the ring and pinion? 3 axleshafts in ten years? Dana 35 does'nt sound like junk to me.
post #100 of 115 Old 03-02-2010, 05:37 AM Thread Starter
PINKANDBLACK
Jeep used them till what 2006? Why would they do that if they were that terrible?
post #101 of 115 Old 03-02-2010, 05:47 AM
JeeperDon
JeeperDon's Avatar
They are not terrible and rarely if ever break when used with OEM size tires and no lockers, as originally intended. They are though the weakest link in the drive train and tend to be the first to go as the Jeep gets taller and more robust, so much so that it's not worth putting money into if you do have any 'make it more robust' plans.
Web Admin for
post #102 of 115 Old 03-02-2010, 03:15 PM
Andy-WhiteTJ
We're all telling you what Don is telling you for a reason...
We've all been there. We've all invested in the D35 at some time or another and realized it was a waste, a BIG waste, of money. You'd be better off looking for a D44 or a Ford 8.8 and having someone weld in brackets. That would be money better spent.
This page will give you an idea what'll happen on the trail:
Another broken Jeep Dana 35c Rear-End.
1998 White TJ with a whole lotta stuff...
Just another member of:
(a 501(c)(7) Not-for-Profit Corporation)
Member:
(Northeast Off-road Vehicle Alliance)
Andy-WhiteTJ is offline
post #103 of 115 Old 03-02-2010, 06:33 PM
BlueRubiconrich
What happens is the shaft and all, walks out and you are unable to drive the Jeep. I'd only put a locker in a non clip Dana 35 and then only run small tires.
post #104 of 115 Old 03-03-2010, 06:24 AM
Voodoo_Chile
OMG, how long did it take to collect the picutures in the link above? oh crap I have a D35 too.
12 JK unlimited 4dr mostly stock until its paid off...
97 TJ 4" Custom RockKrawler long Arms 1"BL, Tummy Tuck, SYE, 35" MTR with Kevlar
or on Facebook www.facebook.com/BaystateJeepers
Voodoo_Chile is offline
post #105 of 115 Old 03-03-2010, 07:29 AM
Badassbabe98
And all of this is exactly the reason that Im building and installing an 8.8 this year. I know Im taking a huge risk, but when I built the Jeep I didnt have enough to pick up the 8.8, but didnt want to have regret on anything else. I'm actually pretty excited to see what if any damage I might have done to my D35 when I take it out next month
What opinion do you guys have of a stock D30 front running 36's with a lock right? think its an ok idea or not? I already have a limited slip 8.8 with 4:10's for the back but was toying with the idea of locking the front too but I wasnt sure if I'd be stupid and would have to throw lots of extra money into the d30 to do so.
Good girls go to Heaven, Jeep girls go anywhere....
Built Not Bought #159
Badassbabe98 is offline
ND wheelers? Fuel North Dakota Jeep Forum 24 11-22-2012 10:29 PM
SC an NC wheelers!!! wingshooter2009 South East USA 0 10-02-2009 10:26 PM
Wheelers for the wounded in MD 2006_Sport North East USA 12 08-23-2009 01:17 PM
Baltimore 4 Wheelers OHV kmj153 North East USA 5 05-14-2009 03:33 AM
Western Mass--Exit 5 on Mass Pike-TRAILS? Orange_Crush North East USA 5 01-23-2008 07:57 AM
