Any "Nuttered" CJ 4.2s local to MA? - JeepForum.com
post #1 of 13 Old 09-25-2012, 11:10 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Cj Any "Nuttered" CJ 4.2s local to MA?
I'm in the process of starting to re-wire my 86 CJ7 4.2 and looking to "nutter" it at the same time. The Jeep doesn't have any vacuum lines or canister in place, so I'd love to see a copy a local nuttered 4.2. I bought the Jeep in pieces as a frame and didn't remove the wiring myself, so I don't know the state of anything.
I'm South of Boston and can provide home-brewed beer for help.
Side question, have you passed inspection since nuttering?
2015 JKU - 6m
Jeeprage is offline
post #2 of 13 Old 09-25-2012, 08:01 PM
BlueRubiconrich
I've got a 86. you don't need emissions for a 86. Im running a weber carb.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 13 Old 09-26-2012, 04:39 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Thanks, but I thought you had to pass a visual, which I would clearly fail without a cat or vacuum lines/charcoal canister.
2015 JKU - 6m
Jeeprage is offline
post #4 of 13 Old 09-28-2012, 08:22 AM
BlueRubiconrich
No never had a problem after they changed the law.
post #5 of 13 Old 09-28-2012, 08:25 AM
BlueRubiconrich
note: 86 had the dana 44 rear and the thick knuckles on the dana 30
they did how ever give us crappy gears 2:73 I had that changed out years ago to 3:73's
post #6 of 13 Old 09-28-2012, 10:38 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Yeah, what size tires are you running? I think I will go with 3.73s when it is time because trail use will be light and I have overdrive for highway use.
2015 JKU - 6m
Jeeprage is offline
post #7 of 13 Old 09-28-2012, 05:11 PM
BlueRubiconrich
I'm running 35" tires, but I have T18 and Scout Dana 300 so I'm geared low for 4 Wheeling. If you are gonna run big tires I would go with min 4:10's
Or put a 4 to 1 in your Dana 300
post #8 of 13 Old 09-29-2012, 07:09 AM Thread Starter
Jeeprage
Jeeprage's Avatar
33s are as big as I'm going and could step down to 32s if I rub, but doubt it. I think 3.73s will be enough since I intend to do some highway and no wheeling is local.
2015 JKU - 6m
Jeeprage is offline
post #9 of 13 Old 09-30-2012, 08:54 AM
BlueRubiconrich
Dana 44 case 2:73-3:73 3:92-5:88
post #10 of 13 Old 10-02-2012, 04:56 PM
DBLJ
DBLJ's Avatar
If you ever need a hand, I'm over in East Braintree.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #11 of 13 Old 10-02-2012, 05:59 PM Thread Starter
Jeeprage
Jeeprage's Avatar
Thanks. Right now I'm in most need of wiring help and to get this thing started. Probably only another month or so before things slow for the winter.
You have a lifted LJ? Seen one around and it was parked around the corner the other day by another lifted TJ.
2015 JKU - 6m
Jeeprage is offline
post #12 of 13 Old 10-04-2012, 03:30 AM
DBLJ
DBLJ's Avatar
Yup. It was parked beside a JK at SouthSide the other night, and also beside a JK at the mall. No TJs that I know of.
DBLJ is offline
post #13 of 13 Old 04-01-2013, 01:01 PM Thread Starter
Jeeprage
Jeeprage's Avatar
Any Braintree area CJ owners around to help trouble shoot some wiring? What I really need is a running (and ideally nuttered) late 4.2 CJ next to me so that I can copy the wiring or trouble shoot with. I can't get this thing going for the life of me.
2015 JKU - 6m
Jeeprage is offline
Local Engine Shop? Jako75 Massachusetts Jeep Forum 2 08-14-2012 07:15 AM
35" BFG KM2 Raynham, ma BlueRubiconrich Massachusetts Jeep Forum 4 07-04-2012 03:25 PM
Anyone local to Townsend that can help me get out of 4lo? aaron7 Massachusetts Jeep Forum 7 11-30-2011 01:00 PM
Looking for local axle shop in Southern Worcester County or Northern Rhode Island weerwolv Massachusetts Jeep Forum 9 08-17-2011 04:44 PM
"Rocky Wood Lane" Taunton Ma. 2DoorXJ91 Massachusetts Jeep Forum 15 09-24-2010 07:05 AM
