-   Massachusetts Jeep Forum (http://www.jeepforum.com/forum/f357/)
-   -   Any "Nuttered" CJ 4.2s local to MA? (http://www.jeepforum.com/forum/f357/any-nuttered-cj-4-2s-local-ma-1420961/)
Jeeprage 09-25-2012 11:10 AM
I'm in the process of starting to re-wire my 86 CJ7 4.2 and looking to "nutter" it at the same time. The Jeep doesn't have any vacuum lines or canister in place, so I'd love to see a copy a local nuttered 4.2. I bought the Jeep in pieces as a frame and didn't remove the wiring myself, so I don't know the state of anything.
I'm South of Boston and can provide home-brewed beer for help.
Side question, have you passed inspection since nuttering?
BlueRubiconrich 09-25-2012 08:01 PM
I've got a 86. you don't need emissions for a 86. Im running a weber carb.
Jeeprage 09-26-2012 04:39 AM
Thanks, but I thought you had to pass a visual, which I would clearly fail without a cat or vacuum lines/charcoal canister.
BlueRubiconrich 09-28-2012 08:22 AM
No never had a problem after they changed the law.
BlueRubiconrich 09-28-2012 08:25 AM
note: 86 had the dana 44 rear and the thick knuckles on the dana 30
they did how ever give us crappy gears 2:73 I had that changed out years ago to 3:73's
Jeeprage 09-28-2012 10:38 AM
Yeah, what size tires are you running? I think I will go with 3.73s when it is time because trail use will be light and I have overdrive for highway use.
BlueRubiconrich 09-28-2012 05:11 PM
I'm running 35" tires, but I have T18 and Scout Dana 300 so I'm geared low for 4 Wheeling. If you are gonna run big tires I would go with min 4:10's
Or put a 4 to 1 in your Dana 300
Jeeprage 09-29-2012 07:09 AM
33s are as big as I'm going and could step down to 32s if I rub, but doubt it. I think 3.73s will be enough since I intend to do some highway and no wheeling is local.
BlueRubiconrich 09-30-2012 08:54 AM
Dana 44 case 2:73-3:73 3:92-5:88
DBLJ 10-02-2012 04:56 PM
If you ever need a hand, I'm over in East Braintree.
Jeeprage 10-02-2012 05:59 PM
Thanks. Right now I'm in most need of wiring help and to get this thing started. Probably only another month or so before things slow for the winter.
You have a lifted LJ? Seen one around and it was parked around the corner the other day by another lifted TJ.
DBLJ 10-04-2012 03:30 AM
Yup. It was parked beside a JK at SouthSide the other night, and also beside a JK at the mall. No TJs that I know of.
Jeeprage 04-01-2013 01:01 PM
Any Braintree area CJ owners around to help trouble shoot some wiring? What I really need is a running (and ideally nuttered) late 4.2 CJ next to me so that I can copy the wiring or trouble shoot with. I can't get this thing going for the life of me.
The time now is 08:26 PM.
