Old Florida Road - Page 3 - JeepForum.com
post #31 of 220 Old 04-16-2009, 08:06 PM
DoinSumthin
Just for the record, I live right down the street from OFR. There is no posted signs up for the road itself, however, like everyone said. The round abouts are private property and posted. If you go off the road, you could be asking for trouble, otherwise, its all good. I am actually planning to run this myself for the first time on Sunday. I have a TJ on 35s with a winch. I am going with a few friends too. So whoever is going on the 19th, we may see you up there!
96 Cherokee XJ Stock for the minute.
SOLD: 2005 Wranlger Sport. Dana 44 rear, 30 front. RE 3.5" Std Lift, 1.25" JKS BL & 1" MML, Rugged Ridge spacers, .75 front coil spacers, 35x12.5 15 BFG M/T tires, Superwinch EPi9, JKS Discos
DoinSumthin is offline
post #32 of 220 Old 04-16-2009, 08:14 PM
DoinSumthin
Oh yeah, and I dont know how many Jeeps have gone through there yet, if any. But last time I hiked up there, there was trees down, so bring something to cut trees with just in case.
post #33 of 220 Old 04-25-2009, 06:04 PM
7slotgrills
Are there still tress down on OFR?Has someone been up it this year?
Rubicon Rich
86 CJ7
05 TJ Rubicon
51 M100
7slotgrills is offline
post #34 of 220 Old 04-26-2009, 07:57 PM
DoinSumthin
Went all the way through last weekend. All is good! Only problem to this is that you would have to go through the pond if you want to come out in Savoy/Florida. The trail going around the pond still has many trees down across it.
post #35 of 220 Old 04-26-2009, 08:08 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Who do you think clears the trails? Our club brings chainsaws and hand saws on rides this time of year. If we run into down trees across the trail (only), we clear them. We had one 2' in diameter across a trail a month ago. It took an hour+ and winches to clear it.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #36 of 220 Old 04-27-2009, 06:22 AM
Liza
Actually the trail around the pond is State land and using that trail is tresspassing. In order to run the trail straight through, you should be going through the water hole on the high side, away from the marsh. That side has a fairly firm bottom.
Field & Forest Recreation Area
Summit Crawlers
Liza is offline
post #37 of 220 Old 05-01-2009, 09:47 AM
DoinSumthin
Oh, I thought there was some issue with going through the water? I did go through it though, was pretty deep.
I dont have a chainsaw, wish I did though because there were some spots I would have like to clean up a little more. I need to join a club too.
post #38 of 220 Old 05-01-2009, 07:16 PM
vwmaniacx
The water problem is with the Mabell trail, not OFR. Do you have any pictures?
you can go a long way with a smile . You can go a lot farther with a smile and a gun . -Al Capone
vwmaniacx is offline
post #39 of 220 Old 05-02-2009, 05:20 AM
DoinSumthin
Yeah I got pics, just no way to post them on here. Im not a supporter, so it doesnt allow.
post #40 of 220 Old 05-02-2009, 05:28 AM
DoinSumthin
Originally Posted by ToxicTurtle View Post
My 2 pennies:
OFR is a difficult road. A rig on 31s will most likely get some damage and may likely end up with some broken part that may make it difficult to drive out and/or drive on the road. It will also need to be dragged over not just the main obstacles but many spots throughout the road.
BTW, when I went through, we had a CJ on 31s. Only time he had a problem was when he got hung up on a tree in one of the water holes near the end on the FL side. Otherwise, he went through just fine, which was very surprising to all of us! He did bottom a few times, but never needed to be dragged. No damage either.
post #41 of 220 Old 05-02-2009, 05:38 AM
vwmaniacx
Just post them up, we'll still be able to click the clicks.
post #42 of 220 Old 05-02-2009, 05:47 AM
DoinSumthin
One more update.
Thanks to Northeast Association of 4WD Clubs
Old Florida RD Update 02/01/06
By: NEA4WDC
Background
The NorthEast Association of 4WD Clubs and its members formally recognized the water hole on Old Florida Road as an environmentally sensitive area. In keeping with our goals of minimizing our impacts on the environment, we instructed our members and advised all motorized users of Old Florida Road to - not cross the water hole. We understood this issue would be highly contested.
The following information was received from findings of an Environmental Impact Study contracted by the NEA. The information contains regulations and laws to consider that could be used against you if cited for wetland violations:
My advice would be to turn around and not go through the water. I'm not saying you can't but just giving posting the facts so you can make your own educated decision. If caught and ticketed for traveling through the water you could face massive fines for wetland and wildlife violations. The decision for NEA clubs and their members to turn around is still in place.
You can read the whole story at http://www.nea4wd.org/articles/index...article_id=180
Now this was from 2006, and I haven't found an update on this saying that passing through the waterhole was now allowed, therefore I would assume this law still stands firm.
post #43 of 220 Old 05-03-2009, 04:20 PM
Smtty58
The current issue with the OFR water hole is trespassing if you take the wrong line through it. Read some of the previous posts here for the correct line.
90 YJ, 4.2, AX-15
86 K1500, 305, 700R4
Smtty58 is offline
post #44 of 220 Old 05-03-2009, 05:54 PM
thejafe
thejafe's Avatar
Brett, clear out your PM's!
thejafe is offline
post #45 of 220 Old 05-03-2009, 06:49 PM
DoinSumthin
Yeah, who knows the story on the OFR waterhole, I hear so many different stories. PMs are cleared too BTW. I replied to one.
Here is a couple pics.
This is where he got hung up on a tree.
Hope those links worked.
Jacksonville Florida mcavana Florida Jeep Forum 19 04-05-2015 07:43 AM
Anyone around S Georgia/N Florida? Kharismattack Florida Jeep Forum 6 01-06-2010 07:16 AM
Old Florida road aug 1st NICU North East USA 5 07-31-2009 05:03 PM
SE Florida jeepallthetime Florida Jeep Forum 0 05-03-2008 06:40 PM
florida? TJSport01 Florida Jeep Forum 32 12-05-2007 07:43 PM
