Old Florida Road - Page 13 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > North East USA > Vermont Jeep Forum > Old Florida Road
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 06-30-2012, 03:21 PM   #181
BlueRubiconrich
Ok this is what the first climb looks like now. That's MY CJ7 with a 4" lift 1" body lift and 35" tires.
and lockers front and rear I may add. years past I've made it and I have not. I did not make it this year 2012
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline   Reply With Quote Quick reply to this message
Unread 06-30-2012, 04:56 PM   #182
YJames90
Thats awesome that its getting harder. That should lessen traffic and add to the fun factor
My 2.5 to 4.3 swap thread
http://www.jeepforum.com/forum/f12/4...begun-1237704/
YJames90 is offline   Reply With Quote Quick reply to this message
Unread 06-30-2012, 05:42 PM   #183
djflyy
Next month or early August to run this. Can't wait.
www.northshorejeeps.com
djflyy is offline   Reply With Quote Quick reply to this message
Unread 08-09-2012, 09:15 PM   #184
DoinSumthin
Damn. That trail looks like more fun now! I need another Jeep so I can run it. I can say back a few years ago, I ran it with 4" of lift and 35" tires and MML, and I would hit in a few spots. Whoever is thinking of running this trail on 30" or 31" have done lost their mind! I hope you are behind someone that is capable so they can drag you over every rock along the way! I've run this trail several times just out of bordem. I think a minimum of 33's and a 3.5" lift to make it. And should have at least a LSD in the rear. And, DO NOT forget recovery gear!
With all that being said, please post more pics of this trail, as I am curious to know how it all looks.
96 Cherokee XJ Stock for the minute.
SOLD: 2005 Wranlger Sport. Dana 44 rear, 30 front. RE 3.5" Std Lift, 1.25" JKS BL & 1" MML, Rugged Ridge spacers, .75 front coil spacers, 35x12.5 15 BFG M/T tires, Superwinch EPi9, JKS Discos
DoinSumthin is offline   Reply With Quote Quick reply to this message
Unread 08-10-2012, 07:12 AM   #185
YJames90
You Sir are very lucky to be living in Adams. So close to good trails
Unread 08-10-2012, 09:15 AM   #186
DoinSumthin
I hear ya, but unfortunately, people do dumb things in their life. One of mine is selling my jeep. I can no longer have fun on that trail, but I am in the market to buy another one that I can beat the hell out of it in the woods and not care. That's about the only trail in the area that is good, other than MaBell. But I hear mixed stories about that trail being open still.
Unread 08-10-2012, 09:50 AM   #187
BlueRubiconrich
OFR is still open. And there are other roads near bye that are good too.
I won't post there names.
Unread 08-13-2012, 07:57 PM   #188
YJames90
Weve done a few others in the area and MaBell .Have to get back there soon
Unread 08-27-2012, 07:59 PM   #189
DoinSumthin
I need some info from the people running XJs. I want to know what size lift and tires they are using to safely make it through OFR. I know what it takes with the TJ, but everything is different with the XJ. Also, is it more necessary to be locked with an XJ vs. a TJ to avoid winching? I have never done the trail with a Cherokee.
Unread 08-28-2012, 07:13 PM   #190
BlueRubiconrich
tire size would be the same as the height of the bottom of the axle would be the same (or close to it). As of now I would recomend a min 33" tire.and a locker is very helpfull. The first challange is a 4' rock wall if you don't make it you will have to winch as there is no go around that is private land. I will be going up there soon. PM me.
Unread 08-28-2012, 07:23 PM   #191
DoinSumthin
I am very familiar with the trail. I have probably ran it 30 or so times. I lived 2 miles from it when I lived in Adams.
33s were minimum with a TJ, too. But with a longer wheel base on the Cherokee, I didn't know if 33s were still a safe bet. The step up wasnt so much the problem for me, either. It was a little further in where you hit the big boulders and water.
Unread 08-30-2012, 07:21 PM   #192
BlueRubiconrich
Last time were were there in June the longer wheelbases did better.
Unread 08-30-2012, 07:36 PM   #193
DoinSumthin
Yeah. That's what I was wondering. Didn't know if the longer wheel base got caught more often on the underside than a TJ, or wrangler for that matter. Just want to build up my XJ the right way, the first time.
Unread 08-31-2012, 01:34 PM   #194
BlueRubiconrich
Ex: A buddy had a TJL 4" lift, belly up pan and 33" tires. He made it up.
Unread 08-31-2012, 10:47 PM   #195
DoinSumthin
Good info. I was on 35s with an 3.5" lift, plus a 1" MML, and 1.25 BL on my old TJ. Didn't know if I needed more than that. My plan is a RE 5.5" lift with 35's and trim the fenders for the XJ. I loved running OFR, so I need a setup that will do it in the XJ.
